Lift |
Lift |
Amphicar770 |
Feb 18 2018, 03:26 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
I have a Greg Smith 4 post with two rolling Jack's so I can have all 4 wheels in the air at once. Very happy with it. Yes, it has safety stops and whenever I lift I then lower it to a safety lock as you should.
2 post is more flexible but harder to install. I've heard you want articulating arms. |
patssle |
Feb 18 2018, 03:34 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I have the two post Atlas lift as well and it's definitely one of the best things I've ever purchased. ZERO regrets. Everything becomes so much easier. And you have complete access to 99% of the car with a two post over four.
Andyrew |
Feb 18 2018, 03:40 PM
My dad had a 2 post and my uncle had a 4 post. The 2 post was much better as a tool, the 4 post is better at storage. Im looking at a 4 post for my house.
jhynesrockmtn |
Feb 18 2018, 03:43 PM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I'm lucky to have a shop behind the house. I built it with 2 lifts in mind. The two post for mostly work although it is used for storage as well. I can fit a 911 under the car above when needed. I get the 996 on by driving onto some plywood pieces I cut out. Only takes 1/2 inch of lift to get the arms under it. Pulling the brakes off of the race car for rebuilding and will be pulling the engine in the next couple of weeks. I bought mine locally and had them do the install.
Cracker |
Feb 18 2018, 04:17 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Now some folks are simply showing off! (IMG:style_emoticons/default/biggrin.gif)
Very nice indeed and it appears you are proving the saying true...hobbyists will grow to capacity! (IMG:style_emoticons/default/poke.gif) What formula chassis is laying there unloved? Tony "I'm lucky..." |
mihai914 |
Feb 18 2018, 05:09 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Since the truck is part of the equation, a name brand lift like Rotary is the best way to go, made in the US preferably.
You can see why here A good quality second hand lift is better than a cheap new one IMHO. |
budk |
Feb 18 2018, 07:08 PM
Yes! It's a Bumblebee! Group: Members Posts: 678 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
I have a 4 post 9k Bend-pak with a rolling hydraulic jack and a jack support that I can use if I need to have all 4 wheels off at the same time. I needed storage which is why I went with 4 post. i usually keep a car on it along with all the other junk I need out of my way. I can do engine drops with it as well.
jhynesrockmtn |
Feb 18 2018, 08:16 PM
Now some folks are simply showing off! (IMG:style_emoticons/default/biggrin.gif) Very nice indeed and it appears you are proving the saying true...hobbyists will grow to capacity! (IMG:style_emoticons/default/poke.gif) What formula chassis is laying there unloved? Tony "I'm lucky..." So very true, I have grown into this place and in some ways outgrown it! :-) That is a 1969 RCA FV. It's not as bad off as the picture. I sold my very nice Zink last summer and will put this one back together sometime this year. |
Cracker |
Feb 18 2018, 08:29 PM
Pretty cool LITTLE cars! My feet would be 3-feet beyond the pedals!
Tony |
davehg |
Feb 18 2018, 11:14 PM
Member Group: Members Posts: 183 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
I have a 4 post lift mostly because I needed to lift an 8000 lb diesel pickup. A two post would require 8-12” concrete floor to safely support, and I’d still feel odd about working under a heavy truck with a two post. I can get by with 6” floors with rebar reinforcement.
I got a rolling jack to lift the cars up for brakes and tires. You can get two or just use the bottle jacks to hold up one side. The jacks are air powered and you need a compressor, same for the safety locks for the lift. Much more stable for storage. If storage and heavy lifting capacity were not considerations I would opt for a 2 post. Bendpak seemed like the value choice. Rotary was nice but more spendy. I don’t use the lift enough to warrant the extra spend. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-21443-1519017284.1.jpg) |
jhynesrockmtn |
Feb 18 2018, 11:23 PM
I am 6'1" and fit just fine :-)
sixnotfour |
Feb 19 2018, 12:05 AM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
since the thread is jacked...added storage
bulitt |
Feb 19 2018, 04:20 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
You can do more using a 2 post. 4 post is better for storing a car. How would you do a brake job using a 4 post and all wheels are under load? I made the mistake of getting a lift with cables and a hose on the floor (it has a cover / ramp). This gets in the way a lot more than I like. Think moving a transmission jack from front to rear. Simple. you raise the car on the 4 post slide two heavy 2"x2"x7' steel square tubes under the car frame with wooden blocking under both ends of the tubes. Lower the 4 post your car is suspended in the air. I agree that a 2 post is more convenient if dropping an engine frequently. Or working on suspension/brake bits. But dropping an engine can be done with a 4 post if you are careful and safe. I have learned the uses of my 4 post are only limited by my imagination... Back my pick-up bed under it to unload a motor. Split a Tractor to change out the torque tube. Work on other stuff- tractors, zero turns, etc. Store all sort of stuff on it- lawnmowers, welder, boxes of parts etc... Changing an engine...I put some jackstands under the car before getting underneath it... |
mlindner |
Feb 19 2018, 07:21 AM
Senior Member Group: Members Posts: 1,516 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
dcheek |
Feb 19 2018, 07:27 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
This subject has been covered many times in this forum. Most of the time people want a portable jacking system. They are more expensive and some only raise a couple of feet. You are smart wanting a 2 post, especially for P cars and air cooled VW's. I have an Atlas brand lift from Greg Smith Equipment. It's the least expensive they have and also the the lowest clearance. My ceilings are 10 1/2 feet. I can lift the 914 and be able to walk under it (I'm 6'2"). Can't stand under a Beetle though. I paid $1445.00, no shipping, no sales tax because I picked it up at the Delaware warehouse. We actually picked up two lifts using a car trailer. It took 2 3/4 hours to install with the help of a couple of friends. The second one took about 2 hours. I hired an electrician to wire in 220 volts. The model is a BP 8000, 8000 lb. lift. I've had it for several years and have changed 2 clutches, 2 complete brake jobs and tie rods. I've made my money back already, plus it gives to extra car storage. Dave What are the concrete requirements for that lift? Thanks 4" minimum - no rebar Dave |
80cap |
Feb 19 2018, 08:59 AM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
What makes a 4 post more difficult to drop an engine?
Cracker |
Feb 19 2018, 09:17 AM
LOL! Yikes! How did you attach the drops to the 4x4 posts? Thanks and a thumbs up for creativity! (IMG:style_emoticons/default/smilie_pokal.gif)
Tony |
Cracker |
Feb 19 2018, 09:20 AM
The challenge would be the restricted access to everything under the tread plates and potential interference with the same (engine mount bar, etc.) I need a little over 48" of open space between runners to make it feasible with a 4 post.
T What makes a 4 post more difficult to drop an engine? |
SKL1 |
Feb 19 2018, 09:23 AM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Space between the tracks makes it more difficult to drop the engine etc but rolling jacks do help with servicing on a 4 post. I have a 4 post in AZ. I do some servicing but it mainly allows me more storage at home.
My son has a 2 post in IA- I couldn't put that in at AZ because the floor had pre-tension rods and you can't drill into it. As stated, 2 post is much better for servicing etc. |
GeorgeRud |
Feb 19 2018, 09:43 AM
Lo-Fi Version | Time is now: 3rd May 2024 - 02:07 PM |
