Lift |
Lift |
dcheek |
Feb 19 2018, 10:28 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
Space between the tracks makes it more difficult to drop the engine etc but rolling jacks do help with servicing on a 4 post. I have a 4 post in AZ. I do some servicing but it mainly allows me more storage at home. My son has a 2 post in IA- I couldn't put that in at AZ because the floor had pre-tension rods and you can't drill into it. As stated, 2 post is much better for servicing etc. This garage is WAY to neat. Please dump some oil or something to make me feel at home! Dave |
burton73 |
Feb 19 2018, 01:02 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Looks like you could get 1 inche of clearance on these lifts. Tight but it would work.
I have to park my 914 or Carrera back wards with the top off and windows down so it will fit a beam that holds up 2 of my bedrooms on the second floor that runs 90 degrees to the car. What me worry? Bob B Atlas® RJ-45: Measurement A must be between 35" - 51" Measurement B must be 1 ½" or wider Measurement C must be between 1" and 1 ¾" Atlas® RJ-6000: Measurement A must be between 32"-52" Measurement B must be 1 1/8" or wider Measurement C must be at least ¾" Atlas® RJ-6: Measurement A must be between 32"-48" Measurement B must be 1 1/8" or wider Measurement C must be at least ¾" Atlas® RJ-7000: Measurement A must be between 32"-52" Measurement B must be 1 1/8" or wider Measurement C must be at least ¾" |
76-914 |
Feb 19 2018, 01:40 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I also use my lift to raise the 914 to a comfortable work height. My back loves me for it. Why bend over to work when you can bring it up to an acceptable height ? (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 3rd May 2024 - 06:59 PM |
