White smoke? |
White smoke? |
VaccaRabite |
Feb 18 2018, 11:46 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
https://www.youtube.com/watch?v=Ib4VMyWAwl8 Got Matt's car running this weekend after a few years down. 123 ignition installed and timed. Valves adjusted. Car is a 1.7 with stock injection. Its blowing prodigious amounts of white smoke when the engine is under load. I did not check compression. Matt assumes a vacuum leak, which is certainly possible. Curious notes: all the valves were tight EXCEPT the valves for cylinder 3, which were in spec. Okay brain trust. What'ca got? Zach |
sithot |
Feb 19 2018, 09:14 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Once witnessed a 3.0SC that bent valves with a missed shift doing a similar thing as unburnt fuel went to vapor straight out the tailpipe.
From personal experience I had a fuel distributor in a '74 911 I owned develop a pin hole in the metering plate. Looked like a mosquito fogger. UNBURNT FUEL and some blue smoke. Regarding sitting up for a while: Years ago I bought a barn find BMW R69S. It has sat for a few years and while it cleaned up beautifully, it did not run. The gas tank was a mess and I spent 2 weeks cleaning it. Care had to be exercised as the bike was a rare color and the paint was original. Used acid, nuts and bolts and a lot of neutralizer. It was re-coated with a PPG 2 part expoxy product I've had good luck with. FWIW, the coating is now over 15 year old and is still in perfect condition. The engine had little compression. I loosened all the valves and took a dead blow hammer to the stems to knock off any debris/carbon/rust. Did a complete tune up (points, condenser, valve adjustment, oil change and brand new (now NLA) Bing carburetors. Pumped 30 weight oil into the cylinders and spent about 15 minutes kicking it over. Re-checked compression and deemed it was enough to get it started. It did start and smoked like freight train while blowing out rust and other debris in the mufflers. Next came the "Italian Tune Up". I had already decided to do a top-end if necessary but thought the bike deserved a chance. These are very robust machines. I took it out and ran it up to redline (7,000+rpm) in 1st an 2nd and then cruised in 3rd for a cool down. This was repeated for about a half dozen times. Rode back to the garage and dumped the oil. Re-filled the sump and rode it for an hour or so. It performed flawlessly. To this day this bike is still one of the strongest running vintage BMWs I've ever ridden and I've had a few. FWIW: It's with a close friend who considers it one the best bikes in his collection of vintage BMW motorcycles. AND IT DOES NOT SMOKE AT ALL (IMG:style_emoticons/default/biggrin.gif) |
Dave_Darling |
Feb 19 2018, 03:30 PM
sithot |
Feb 19 2018, 03:33 PM
From personal experience I had a fuel distributor in a '74 911 I owned develop a pin hole in the metering plate. Looked like a mosquito fogger. UNBURNT FUEL and some blue smoke. Unburned fuel smells a lot like fuel. Burning oil smells different. --DD No kidding? LOL |
Dave_Darling |
Feb 19 2018, 04:27 PM
No kidding? LOL Just pointing out that you can use your sense of smell to help figure out what is leaking... If the cloud smells sweet like anti-freeze, something is really wrong with your 914!!! (IMG:style_emoticons/default/biggrin.gif) --DD |
plas76targa |
Feb 20 2018, 06:33 AM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
No kidding? LOL Just pointing out that you can use your sense of smell to help figure out what is leaking... If the cloud smells sweet like anti-freeze, something is really wrong with your 914!!! (IMG:style_emoticons/default/biggrin.gif) --DD Unfortunately my senses for taste and smell died 10+ yrs ago. I count on trustworthy friends to comment on the aroma the cars exhaust. I’ll add that there is oil all over the heat exchangers, most had burned off by time the video was made. I hope the new cork gaskets on valve covers stop further oil leaks or i’ll Have more to dig into and remedy. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:25 PM |
