Roll couple and rear tire spin |
yeahmag |
Feb 19 2018, 06:09 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Just got through my first autocross after the rebuild and the car was great! With a good friend and hot-shoe behind the wheel the car was the 2nd fastest aircooled car and #7 PAX adjusted in a pretty big field (PCA OCR).
I'd like to get better control of the rear, inner tire. We were spinning it up quite a bit. I'm thinking more rear spring is the correct approach. Current set up: Front: 21mm torsion bars 19mm sway bar set 3/4 hard Rebel Racing Bushings Monoball camber plates 19mm raised spindles Bilstein Sports 2.5 degrees camber 5 degrees caster 1/16" toe out Rear 225lb springs Rebel Racing Bushings No rear bar Koni Yellows (full soft) 2.0 degrees camber 1/16" toe in Tires are fairly used up Hankook C71 Z214 in a square set up (205/50-15) run at about 22lbs hot. Granted replacing the tires would help, but even when they were new it would spin these up. I have 275lb springs sitting around that I can swap in. Am I heading in the right direction? Me https://www.youtube.com/watch?v=hdMUYqusga4 Evan (damn he's fast) https://www.youtube.com/watch?v=mI6O_gVzPuA |
ChrisFoley |
Feb 20 2018, 07:34 AM
I am Tangerine Racing Group: Members Posts: 7,928 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Tighten the front bar and try that before making any other changes.
stownsen914 |
Feb 20 2018, 09:45 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I agree with your thought to use heavier rear springs instead of the rear swaybar. Try Chris's suggestion. Also, I see you mention having the rear Koni's on full soft. I'm trying to reason in my head whether additional rebound damping (that is what is adjustable on the Koni's) would help or hurt wheel spin. You mention that the rear feels wallowy. Adding rebound damping will help alleviate this. It may be worth trying since it's easy to try.
The sure fire fixes would be wider tires and/or an LSD of course (IMG:style_emoticons/default/smile.gif) Scott |
Lo-Fi Version | Time is now: 22nd May 2024 - 11:32 AM |
