Roll couple and rear tire spin |
yeahmag |
Feb 19 2018, 06:09 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Just got through my first autocross after the rebuild and the car was great! With a good friend and hot-shoe behind the wheel the car was the 2nd fastest aircooled car and #7 PAX adjusted in a pretty big field (PCA OCR).
I'd like to get better control of the rear, inner tire. We were spinning it up quite a bit. I'm thinking more rear spring is the correct approach. Current set up: Front: 21mm torsion bars 19mm sway bar set 3/4 hard Rebel Racing Bushings Monoball camber plates 19mm raised spindles Bilstein Sports 2.5 degrees camber 5 degrees caster 1/16" toe out Rear 225lb springs Rebel Racing Bushings No rear bar Koni Yellows (full soft) 2.0 degrees camber 1/16" toe in Tires are fairly used up Hankook C71 Z214 in a square set up (205/50-15) run at about 22lbs hot. Granted replacing the tires would help, but even when they were new it would spin these up. I have 275lb springs sitting around that I can swap in. Am I heading in the right direction? Me https://www.youtube.com/watch?v=hdMUYqusga4 Evan (damn he's fast) https://www.youtube.com/watch?v=mI6O_gVzPuA |
yeahmag |
Feb 20 2018, 03:33 PM
(Let me know if you get sick of talking about this...)
Chris, That seems counterintuitive to me. The heavier springs (8" coilovers) can't hold the wheel up. A sway bar certainly can and would (on the same axle). The spring can ONLY push DOWN (or hold the car up depending on how you want to discuss it). Is the idea to use the diagonal to hold the opposite corner (on diagonal) down? Brant, It has has a Mad Dog stiffening kit and some suspension stiffening - no cage. Scott, probably only around 130HP, but I've not dynoed it. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:35 PM |
