Roll couple and rear tire spin |
yeahmag |
Feb 19 2018, 06:09 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Just got through my first autocross after the rebuild and the car was great! With a good friend and hot-shoe behind the wheel the car was the 2nd fastest aircooled car and #7 PAX adjusted in a pretty big field (PCA OCR).
I'd like to get better control of the rear, inner tire. We were spinning it up quite a bit. I'm thinking more rear spring is the correct approach. Current set up: Front: 21mm torsion bars 19mm sway bar set 3/4 hard Rebel Racing Bushings Monoball camber plates 19mm raised spindles Bilstein Sports 2.5 degrees camber 5 degrees caster 1/16" toe out Rear 225lb springs Rebel Racing Bushings No rear bar Koni Yellows (full soft) 2.0 degrees camber 1/16" toe in Tires are fairly used up Hankook C71 Z214 in a square set up (205/50-15) run at about 22lbs hot. Granted replacing the tires would help, but even when they were new it would spin these up. I have 275lb springs sitting around that I can swap in. Am I heading in the right direction? Me https://www.youtube.com/watch?v=hdMUYqusga4 Evan (damn he's fast) https://www.youtube.com/watch?v=mI6O_gVzPuA |
pcar916 |
Feb 23 2018, 06:01 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
My car is where I like it on a road course, and got far better when I installed an LSD. But for AX it was immediate and terminal understeer because the LSD breakaway is set far too tight for that. That said my machine is stiffer than yours on both ends of the car and has roughly 225hp at the wheels. If I was to build a box for AX with a non-open diff, it would likely be a torque-bias diff instead.
I'm liking Chris' solution and tweak with tire pressures when you get it close. Good Luck |
yeahmag |
Feb 23 2018, 11:45 AM
I'm constantly tweaking tire pressures, but we settled on roughly 21lbs HOT front and rear worked best on the day of testing. I'm sure newer DOT-Rs would be have a bit different.
pcar916 |
Feb 23 2018, 05:45 PM
Lo-Fi Version | Time is now: 22nd May 2024 - 01:19 AM |
