Roll couple and rear tire spin |
yeahmag |
Feb 19 2018, 06:09 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Just got through my first autocross after the rebuild and the car was great! With a good friend and hot-shoe behind the wheel the car was the 2nd fastest aircooled car and #7 PAX adjusted in a pretty big field (PCA OCR).
I'd like to get better control of the rear, inner tire. We were spinning it up quite a bit. I'm thinking more rear spring is the correct approach. Current set up: Front: 21mm torsion bars 19mm sway bar set 3/4 hard Rebel Racing Bushings Monoball camber plates 19mm raised spindles Bilstein Sports 2.5 degrees camber 5 degrees caster 1/16" toe out Rear 225lb springs Rebel Racing Bushings No rear bar Koni Yellows (full soft) 2.0 degrees camber 1/16" toe in Tires are fairly used up Hankook C71 Z214 in a square set up (205/50-15) run at about 22lbs hot. Granted replacing the tires would help, but even when they were new it would spin these up. I have 275lb springs sitting around that I can swap in. Am I heading in the right direction? Me https://www.youtube.com/watch?v=hdMUYqusga4 Evan (damn he's fast) https://www.youtube.com/watch?v=mI6O_gVzPuA |
yeahmag |
Feb 23 2018, 05:52 PM
I may have a line on a 22mm sway bar (Gerold) and another member has offered to sell me some 22mm torsion bars. Money and time are the biggest obstacles to testing that setup now.
stownsen914 |
Feb 25 2018, 09:52 AM
So I'll throw this out there ... years ago when I was driving a stock-ish 914 on the track with an approx. 130 hp modified engine, I was getting terrible inner rear wheel shuddering due to lack of traction. The problem disappeared when I switched from regular performance tires to R compound tires. I see you're using Hankooks, which I understand are decent performance tires (it sounds like yours may be on the used up side, for what it's worth), but it may be worth exploring different tires in case the other suggestions don't do eliminate the problem for you.
Scott |
Lo-Fi Version | Time is now: 15th May 2024 - 01:35 PM |
