Turn signals, emergency flashers not working |
ORANGE2 |
Feb 20 2018, 01:17 AM
Newbie Group: Members Posts: 25 Joined: 12-February 03 From: Roanoke, TX Member No.: 305 Region Association: Northstar Region |
Im sorry if this is posted already but can't seem to find it. I have a 74 2.0. My front turn signals come on solid with the turn signal switch, but do not flash. The emergency flashers do not work at all. I checked and rechecked wire positioning on the emergency switch and even swapped switches. I purchased and installed a new flasher relay.. After I installed it they flashed a couple times and blew two fuses. I believe they are positions 8 and 10. If i put 12volts on the output side of position 10 on the fuse block the relay under the passenger seat clicks a few times and then trips my test probe. I've also checked and re checked light wiring at all 4 corners. Is there something else I should be looking for ? any help would be appreciated.
ORANGE2 |
Mar 2 2018, 05:33 PM
Right now I have all lights unplugged and both fuses blow. Not at same time. One as soon as I turn on the key the other with the flasher switch. I’ve tried 3 different switches.
Lo-Fi Version | Time is now: 15th May 2024 - 01:21 PM |
