Turn signals, emergency flashers not working |
ORANGE2 |
Feb 20 2018, 01:17 AM
Newbie Group: Members Posts: 25 Joined: 12-February 03 From: Roanoke, TX Member No.: 305 Region Association: Northstar Region |
Im sorry if this is posted already but can't seem to find it. I have a 74 2.0. My front turn signals come on solid with the turn signal switch, but do not flash. The emergency flashers do not work at all. I checked and rechecked wire positioning on the emergency switch and even swapped switches. I purchased and installed a new flasher relay.. After I installed it they flashed a couple times and blew two fuses. I believe they are positions 8 and 10. If i put 12volts on the output side of position 10 on the fuse block the relay under the passenger seat clicks a few times and then trips my test probe. I've also checked and re checked light wiring at all 4 corners. Is there something else I should be looking for ? any help would be appreciated.
JOEPROPER |
Mar 2 2018, 05:50 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
I would try to break down that wiring diagram and isolate sections of the circuit to eliminate or narrow down the section where the short is.
Lo-Fi Version | Time is now: 15th May 2024 - 12:39 PM |
