Front sway bar strengthening |
defianty |
Feb 20 2018, 08:14 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
My car didn't have sway bars from the factory and I have a Weltmeister to install at the front. I've actually already fitted it and packed it away again before I fit it once the car is painted.
In a conversation with another UK 914 owner we discuss strengthening the inner wing where the bar come through. Here's a pic of what I have at the moment. What's everyone's thought on strengthening this area? (IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.org-6621-1519136078.1.jpg) |
Jeff Hail |
Feb 20 2018, 08:26 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
My car didn't have sway bars from the factory and I have a Weltmeister to install at the front. I've actually already fitted it and packed it away again before I fit it once the car is painted. In a conversation with another UK 914 owner we discuss strengthening the inner wing where the bar come through. Here's a pic of what I have at the moment. What's everyone's thought on strengthening this area? (IMG:http://www.914world.com/bbs2/uploads_offsite/s6.postimg.org-6621-1519136078.1.jpg) Attached image(s) |
914_teener |
Feb 20 2018, 08:56 AM
914 Guru Group: Members Posts: 5,195 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If you are using a stock bar not necessary.
Bigger yes. |
ChrisFoley |
Feb 20 2018, 09:16 AM
I am Tangerine Racing Group: Members Posts: 7,915 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
If you are using a stock bar not necessary. Bigger yes. I disagree. The factory installed reinforcing plates in all cars that received factory anti sway bars. However the one Jeff Hailpern posted a pic of is total overkill for most 914s. I'm pretty sure the ones I make are the only ones with a tri-oval shape which follows the stamped area of the inner fender. |
Morrie |
Feb 20 2018, 10:10 AM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
If you are using a stock bar not necessary. Bigger yes. I disagree. The factory installed reinforcing plates in all cars that received factory anti sway bars. However the one Jeff Hailpern posted a pic of is total overkill for most 914s. I'm pretty sure the ones I make are the only ones with a tri-oval shape which follows the stamped area of the inner fender. Chris, I have seen your stuff in action, modified slightly to fit my friend's 911 chassis (Jamie Novak). I highly recommend this as a preventative measure, and well worth the expense. This is one of those cases where making your own part is not worth the effort when a quality part is out there. |
Wyvern |
Feb 20 2018, 10:37 AM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
Just finished installation of the stock front and rear bar.
I used the Mad Dog reinforcement plate. I do believe it is a bit of overkill for a stock bar, but it is job done right. If I want a bigger bar I am good to go. |
defianty |
Feb 20 2018, 10:58 AM
Hmm, I think I'll fabricate and weld in a reinforcement plate then Shouldn't be too much trouble.
Thanks. |
bbrock |
Feb 20 2018, 11:45 AM
JFG |
Feb 20 2018, 11:49 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Hmm, I think I'll fabricate and weld in a reinforcement plate then Shouldn't be too much trouble. Thanks. When I took mine off it had split all inside the triangular area between the students and bar holes. I fabricated plates for inside the box section under the tank and for the inner wing around the brake hose bracket. |
gothspeed |
Feb 20 2018, 12:19 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I stitch welded some like this on the inside. They were weltmeister brand if I recall correctly. Using stock sway bar. (IMG:style_emoticons/default/smile.gif)
Eric_Shea |
Feb 20 2018, 12:25 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'm with Chris... weld them in. I don't like the "riv-nut" versions above though.
We have them for $30.00 a pair. Probably cheaper than your time welding them up. |
gothspeed |
Feb 20 2018, 12:31 PM
Here is an interesting reinforcement design I have not yet seen. I wish this was around when I did mine. I had to cut the boxed area.
https://www.ebay.com/itm/Porsche-914-Front-...gIAAOSw9GhYZsnC Attached image(s) |
defianty |
Feb 20 2018, 01:38 PM
I stitch welded some like this on the inside. They were weltmeister brand if I recall correctly. Using stock sway bar. (IMG:style_emoticons/default/smile.gif) Ah, now I have some of those they came with the Weltmeister. Never said anything about welding them in though. That's it then, I'll weld them in. Job done. Thanks. |
914_teener |
Feb 20 2018, 05:04 PM
I stitch welded some like this on the inside. They were weltmeister brand if I recall correctly. Using stock sway bar. (IMG:style_emoticons/default/smile.gif) Ah, now I have some of those they came with the Weltmeister. Never said anything about welding them in though. That's it then, I'll weld them in. Job done. Thanks. I also used the nut plate and welded it in. So when you posted a re-enforcement plate and the next poster posted a picture a plate through the whole fender well...I thought you meant that! Definitely you need the "nut plate" on the inside of the fender well to be welded in. There is also a classic thread on this I believe. Unless you drill the mounting holes in true position - ( almost impossible) for this installation....the holes in the fender well need to be slightly oversize to bolt both plate together to compress the bushings. If those holes are oversize the backing plate....or reinforcing plate...could loosen over time due to the torsion of the bar and rip the fender well sheet metal due to it spinning or moving. Am I right Eric and Chris? Wrote a thread on this I believe a while back and I'm getting old....er older. |
bigkensteele |
Feb 20 2018, 05:21 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Here is an interesting reinforcement design I have not yet seen. I wish this was around when I did mine. I had to cut the boxed area. https://www.ebay.com/itm/Porsche-914-Front-...gIAAOSw9GhYZsnC I just bought a kit like this from Brad Mayeur @ 914 Limited. Very bottom of the page below. This is the way to go in my book. http://914ltd.com/store.php?c=1384303079 |
914forme |
Feb 20 2018, 07:09 PM
Here is an interesting reinforcement design I have not yet seen. I wish this was around when I did mine. I had to cut the boxed area. https://www.ebay.com/itm/Porsche-914-Front-...gIAAOSw9GhYZsnC Brad did a great job on these, glad I used them on my latest build. |
iankarr |
Feb 20 2018, 10:23 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I just installed Brad's mount kit this weekend. Welded both sides with no problem. 914_teener is right...the mounting holes inside the fender need to be a little wider to accommodate slight differences in alignment as you drill. Mine only needed a little filing to open up a few holes by a mm or less. I prefer Brad's design where you don't have to cut into the top of the frame support...but you do have to drill into the side to accommodate the bottom mount nut. Overall, I'd guess that the hole is less compromising than cutting a channel. I'll be posting a video of the process as soon as my A-arms are back in and I can finish up installing the bar. |
gothspeed |
Feb 21 2018, 07:05 PM
Awesome, can't wait to see pics or video (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 30th April 2024 - 08:00 AM |
