Topic Change to Ford F250 Rust Repair and Paint., And I'm going to Loctite the crap out of everything.... |
Series9 |
Feb 20 2018, 02:18 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
The car was flat bedded to Series 9 with a "rod knock".
Turned out to be a flywheel knock. Make sure things are torqued up and it doesn't hurt to use some thread locker. Those 5 bolts cost this engine its bottom end. Here are the pictures. Attached thumbnail(s) |
SirAndy |
Feb 20 2018, 02:19 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Outsch ...
(IMG:style_emoticons/default/sad.gif) |
Series9 |
Feb 20 2018, 02:20 PM
And:
Series9 |
And:
Series9 |
Feb 20 2018, 02:21 PM
And:
Series9 |
Feb 20 2018, 02:26 PM
But wait, there's more. This engine is reported to have 6000 miles on it..... Attached thumbnail(s) |
Series9 |
Feb 20 2018, 02:27 PM
And:
Series9 |
Feb 20 2018, 02:28 PM
Nose bearing saddle from the other end. The dowel pin was sitting there at a 45* angle.
JeffBowlsby |
Feb 20 2018, 02:44 PM
914 Wiring Harnesses Group: Members Posts: 8,478 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Hey Joe...VIN of the LE please.
ChrisFoley |
Feb 20 2018, 02:57 PM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
There's no reason to use thread locker on a Type 4 flywheel at all.
When new bolts and a new lock plate are used, along with correct torque of 80 lb-ft, they will not ever come loose on their own. |
Series9 |
Feb 20 2018, 03:29 PM
There's no reason to use thread locker on a Type 4 flywheel at all. When new bolts and a new lock plate are used, along with correct torque of 80 lb-ft, they will not ever come loose on their own. Well, there's no way to truly know on this one. I didn't build it. I didn't torque it. The new parts will get some thread locker for good measure. Cheap insurance. |
Series9 |
Feb 20 2018, 03:30 PM
worn |
Feb 20 2018, 05:04 PM
can't remember Group: Members Posts: 3,147 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
There's no reason to use thread locker on a Type 4 flywheel at all. When new bolts and a new lock plate are used, along with correct torque of 80 lb-ft, they will not ever come loose on their own. Well, there's no way to truly know on this one. I didn't build it. I didn't torque it. The new parts will get some thread locker for good measure. Cheap insurance. So is the case a gonner? |
craig downs |
Feb 21 2018, 02:08 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Had the same thing happen to me and my engine had just a couple thousand on it. Ever time I took my foot off the pedal there was a loud rumble. When I found out what it was 3 of the 5 flywheel bolts were sheared and the flywheel and end of the crank looked worse than yours. I reused the flywheel bolts I had before and looking at some other ones I had after the problem I noticed they were stretched, a costly mistake. I had the end of the crank and the flywheel resurfaced and it's ok now. Also got some new hardened bolts and will never reuse used bolts again.
Series9 |
Feb 21 2018, 08:20 AM
EdwardBlume |
Feb 21 2018, 08:30 AM
So when is someone going to post a link and recommendation as to where to buy new bolts?
johnhora |
Feb 21 2018, 08:31 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
There's no reason to use thread locker on a Type 4 flywheel at all. When new bolts and a new lock plate are used, along with correct torque of 80 lb-ft, they will not ever come loose on their own. (IMG:style_emoticons/default/agree.gif) with Chris... This is one of those items it just pays to use new....cheap insurance. |
TheCabinetmaker |
Feb 21 2018, 10:28 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I agree. Loctite is unnecessary when flywheel is properly installed. I hope I never encounter Loctite on one I'm removing
mepstein |
Feb 21 2018, 12:00 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
veltror |
Feb 22 2018, 01:52 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
So when is someone going to post a link and recommendation as to where to buy new bolts? Flywheel bolts |
Lo-Fi Version | Time is now: 25th April 2024 - 08:32 PM |
