Topic Change to Ford F250 Rust Repair and Paint., And I'm going to Loctite the crap out of everything.... |
Series9 |
Feb 20 2018, 02:18 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
The car was flat bedded to Series 9 with a "rod knock".
Turned out to be a flywheel knock. Make sure things are torqued up and it doesn't hurt to use some thread locker. Those 5 bolts cost this engine its bottom end. Here are the pictures. Attached thumbnail(s) |
ChrisFoley |
Feb 20 2018, 02:57 PM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
There's no reason to use thread locker on a Type 4 flywheel at all.
When new bolts and a new lock plate are used, along with correct torque of 80 lb-ft, they will not ever come loose on their own. |
Series9 |
Feb 20 2018, 03:29 PM
There's no reason to use thread locker on a Type 4 flywheel at all. When new bolts and a new lock plate are used, along with correct torque of 80 lb-ft, they will not ever come loose on their own. Well, there's no way to truly know on this one. I didn't build it. I didn't torque it. The new parts will get some thread locker for good measure. Cheap insurance. |
worn |
Feb 20 2018, 05:04 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
There's no reason to use thread locker on a Type 4 flywheel at all. When new bolts and a new lock plate are used, along with correct torque of 80 lb-ft, they will not ever come loose on their own. Well, there's no way to truly know on this one. I didn't build it. I didn't torque it. The new parts will get some thread locker for good measure. Cheap insurance. So is the case a gonner? |
Lo-Fi Version | Time is now: 8th May 2024 - 11:11 AM |
