Topic Change to Ford F250 Rust Repair and Paint., And I'm going to Loctite the crap out of everything.... |
Series9 |
Feb 20 2018, 02:18 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
The car was flat bedded to Series 9 with a "rod knock".
Turned out to be a flywheel knock. Make sure things are torqued up and it doesn't hurt to use some thread locker. Those 5 bolts cost this engine its bottom end. Here are the pictures. Attached thumbnail(s) |
craig downs |
Feb 21 2018, 02:08 AM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Had the same thing happen to me and my engine had just a couple thousand on it. Ever time I took my foot off the pedal there was a loud rumble. When I found out what it was 3 of the 5 flywheel bolts were sheared and the flywheel and end of the crank looked worse than yours. I reused the flywheel bolts I had before and looking at some other ones I had after the problem I noticed they were stretched, a costly mistake. I had the end of the crank and the flywheel resurfaced and it's ok now. Also got some new hardened bolts and will never reuse used bolts again.
Lo-Fi Version | Time is now: 25th April 2024 - 04:04 AM |
