Went The Wrong Way, 16X7 On Stock Rear With 23.3 Offset |
914Sixer |
Feb 20 2018, 10:30 PM
914 Guru Group: Members Posts: 8,845 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
So I took a chance on putting on 16X7 on a stock body, not going to work. Put the wheel on with no tire and it was easy to see I had a problem. Brake clearance was not a issue but the fender sure was. Stock 4 Fuchs has a 45 ET and the 16x6 Boxster has a 50ET. 23.3 offset was going the wrong way. Looks like I would need a 7R wheel but they are 15".
Mueller |
Feb 20 2018, 11:08 PM
Yea, whomever designed that portion of the car really didn't want 914 owners to have wide tires without painful or expensive modifications.
Fenders look too nice and original to pull or tweak. PO of my car said rear fenders are stock however I think they've been pulled a little. I too have some 23mm 15x7s that are going on the car. Currently with 7's but they are 53mm offset with spacers. I really wish I hadn't given away the extra set of rear trailing arms I had since I'd like to try the Rich Johnson method of moving the hub inboard 20mm or so. |
gothspeed |
Feb 21 2018, 10:19 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Is the suspension 'unsprung' in the pictures? Does anyone know if the suspension tilts inward on compression?
It certainly looks like the wheel will not fit in the pictures. |
sixnotfour |
Feb 21 2018, 10:24 AM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
16 x 7 .5 made from 16x6s
JamesM |
Feb 21 2018, 10:44 AM
Senior Member Group: Members Posts: 1,875 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
So I took a chance on putting on 16X7 on a stock body, not going to work. Put the wheel on with no tire and it was easy to see I had a problem. Brake clearance was not a issue but the fender sure was. Stock 4 Fuchs has a 45 ET and the 16x6 Boxster has a 50ET. 23.3 offset was going the wrong way. Looks like I would need a 7R wheel but they are 15". You want ET35 offset to run 16x7, at least on a bone stock 4 bolt setup. That will let you run 205s and in some cases slightly wider tires on a narrow body. |
Feb 21 2018, 11:53 AM
914 Idiot Group: Members Posts: 14,974 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Is the suspension 'unsprung' in the pictures? Does anyone know if the suspension tilts inward on compression? It will tilt inward some on compression, especially with a bunch of negative camber. I am pretty sure it won't be nearly enough to let you put a tire on that rim and have it fit. --DD |
Feb 21 2018, 12:12 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I don't know why everybody tries so hard to fit 7's on a stock body car. 6's fit great without any mods and fit the same size tire as a 7. If you feel like you need more grip, get a higher performance tire. Very few of us are daily driving our cars. Most of them are sunny day, moderate weather drivers. I bet 99% of 914's age out their tires long before they wear them out. If you really want to be covered, get a second set of wheels and tires for the wetter, colder months.
914Sixer |
Feb 21 2018, 12:56 PM
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route
mmascari |
Feb 21 2018, 01:17 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route Sorry to hear the wheels didnt work. I am also running the Boxster wheels. 6" in front and 7" in the rear. I wish there were other options but I just don't think it is going to happen on my car especially with Boxster calipers. Attached thumbnail(s) |
johnhora |
Feb 21 2018, 02:14 PM
Senior Member Group: Members Posts: 864 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
I don't know why everybody tries so hard to fit 7's on a stock body car. 6's fit great without any mods and fit the same size tire as a 7. If you feel like you need more grip, get a higher performance tire. Very few of us are daily driving our cars. Most of them are sunny day, moderate weather drivers. I bet 99% of 914's age out their tires long before they wear them out. If you really want to be covered, get a second set of wheels and tires for the wetter, colder months. (IMG:style_emoticons/default/agree.gif) Exactly Still plenty of excellent tires in 205/55/16 Plenty of tread width and correct diameter for no speedo issues. |
914Toy |
Feb 21 2018, 02:42 PM
Senior Member Group: Members Posts: 710 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route Sorry to hear the wheels didnt work. I am also running the Boxster wheels. 6" in front and 7" in the rear. I wish there were other options but I just don't think it is going to happen on my car especially with Boxster calipers. I have 7"x16" Fuchs on my car with 205/45 /16R tires. These fit easily in the front with a 1/4' spacer, and the rears require "rolling" the inner fender edges (with baseball bat or equivalent between the tire with the car raised to get the bat in between the tire and the fender) and then gently pulling the fender out a little by hand. |
sixnotfour |
Feb 21 2018, 03:15 PM
QUOTE 6's fit great without any mods and fit the same size tire as a 7 because the lips on sevens are Sexy |
Front yard mechanic |
Feb 21 2018, 03:23 PM
Senior Member Group: Members Posts: 1,144 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route Sorry to hear the wheels didnt work. I am also running the Boxster wheels. 6" in front and 7" in the rear. I wish there were other options but I just don't think it is going to happen on my car especially with Boxster calipers. I have 7"x16" Fuchs on my car with 205/45 /16R tires. These fit easily in the front with a 1/4' spacer, and the rears require "rolling" the inner fender edges (with baseball bat or equivalent between the tire with the car raised to get the bat in between the tire and the fender) and then gently pulling the fender out a little by hand. Nice looking car bat marks and all |
porschetub |
Feb 21 2018, 03:31 PM
Advanced Member Group: Members Posts: 4,695 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route Sorry to hear the wheels didnt work. I am also running the Boxster wheels. 6" in front and 7" in the rear. I wish there were other options but I just don't think it is going to happen on my car especially with Boxster calipers. I have 7"x16" Fuchs on my car with 205/45 /16R tires. These fit easily in the front with a 1/4' spacer, and the rears require "rolling" the inner fender edges (with baseball bat or equivalent between the tire with the car raised to get the bat in between the tire and the fender) and then gently pulling the fender out a little by hand. Have them on my car with a little bit of fender pull ,only one side rubbed and that was over large bumps,I do however have no rear trailing shims,they aren't cambered out too much ,have 205/16 rubber which is plenty on the road. They work for many folks on here. |
Feb 21 2018, 08:37 PM
Custom Member Group: Members Posts: 24,501 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Mark—-OP
What kind of wheel is that? |
914Sixer |
Feb 21 2018, 09:52 PM
Wheel is Euromiester.
Lo-Fi Version | Time is now: 29th March 2024 - 02:15 AM |
