Went The Wrong Way, 16X7 On Stock Rear With 23.3 Offset |
914Sixer |
Feb 20 2018, 10:30 PM
So I took a chance on putting on 16X7 on a stock body, not going to work. Put the wheel on with no tire and it was easy to see I had a problem. Brake clearance was not a issue but the fender sure was. Stock 4 Fuchs has a 45 ET and the 16x6 Boxster has a 50ET. 23.3 offset was going the wrong way. Looks like I would need a 7R wheel but they are 15".
Attached image(s) |
gothspeed |
Feb 21 2018, 10:19 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Is the suspension 'unsprung' in the pictures? Does anyone know if the suspension tilts inward on compression?
It certainly looks like the wheel will not fit in the pictures. |
Dave_Darling |
Feb 21 2018, 11:53 AM
Is the suspension 'unsprung' in the pictures? Does anyone know if the suspension tilts inward on compression? It will tilt inward some on compression, especially with a bunch of negative camber. I am pretty sure it won't be nearly enough to let you put a tire on that rim and have it fit. --DD |
Lo-Fi Version | Time is now: 16th May 2024 - 03:28 AM |
