Went The Wrong Way, 16X7 On Stock Rear With 23.3 Offset |
914Sixer |
Feb 20 2018, 10:30 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
So I took a chance on putting on 16X7 on a stock body, not going to work. Put the wheel on with no tire and it was easy to see I had a problem. Brake clearance was not a issue but the fender sure was. Stock 4 Fuchs has a 45 ET and the 16x6 Boxster has a 50ET. 23.3 offset was going the wrong way. Looks like I would need a 7R wheel but they are 15".
Attached image(s) |
914Sixer |
Feb 21 2018, 12:56 PM
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route
mmascari |
Feb 21 2018, 01:17 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route Sorry to hear the wheels didnt work. I am also running the Boxster wheels. 6" in front and 7" in the rear. I wish there were other options but I just don't think it is going to happen on my car especially with Boxster calipers. Attached thumbnail(s) |
914Toy |
Feb 21 2018, 02:42 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I currently have 16x6 boxsters on all 4 corners. I am using them as rollers. I know the 16x7 boxsters will work on the rears. Might just go that route Sorry to hear the wheels didnt work. I am also running the Boxster wheels. 6" in front and 7" in the rear. I wish there were other options but I just don't think it is going to happen on my car especially with Boxster calipers. I have 7"x16" Fuchs on my car with 205/45 /16R tires. These fit easily in the front with a 1/4' spacer, and the rears require "rolling" the inner fender edges (with baseball bat or equivalent between the tire with the car raised to get the bat in between the tire and the fender) and then gently pulling the fender out a little by hand. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:19 AM |
