Chasis Stiffening for street 914 GT question |
rcarson25 |
Feb 21 2018, 03:16 PM
Member Group: Members Posts: 62 Joined: 15-May 17 From: TN Member No.: 21,103 Region Association: South East States |
So I may have messed up my order of operations here but my car is in paint and I am looking to figure out what chasis reinforcement would make sense for my car. The car is a metal flaired 1970 914-4. The motor is a 2056, the car will mostly be used for spirited driving on the street with 8” wide rears maybe an occasional autox. I have heard some stiffening just adds weight or is not necessary for a mild engine conversion like the 2056. I don’t want to waste money and add extra weight if not necessary.
Currently I am looking at the inner long kit from Maddox and Tangerine Heim rods from the firewall to rear suspension pickup. I look forward to hearing suggestions from those with experience. |
tygaboy |
Feb 21 2018, 03:22 PM
914 Guru Group: Members Posts: 5,244 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
The mods you suggest are the right ones for your application. Tons of posts about going slow when welding in the chassis stiffeners.
And as long as you're going to place an order with Tangerine, treat yourself to a set of Chris' door bar braces to use when installing those stiffeners. Oh, and let me be the first: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
rcarson25 |
Feb 21 2018, 03:46 PM
The mods you suggest are the right ones for your application. Tons of posts about going slow when welding in the chassis stiffeners. And as long as you're going to place an order with Tangerine, treat yourself to a set of Chris' door bar braces to use when installing those stiffeners. Oh, and let me be the first: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Pics will come when I get the car back and can start putting things together. Right now car is not with me but getting some paint issues cleaned up before I get busy on this project. Probably should have done stiffening before paint but is what it is. |
gothspeed |
Feb 21 2018, 05:45 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I will be running a steel flared, aggressive street 914 with probably 8" rears, similar to what you are running with a 2056.
I am keeping the car light and using stock sway bars. If the chassis kits were thinner gauge, I would consider installing them but for now I simply repaired all sheet metal back to original design ... (IMG:style_emoticons/default/smile.gif) I do like the rear suspension console reinforcements to firewall/outer chassis though |
johnhora |
Feb 21 2018, 09:29 PM
Senior Member Group: Members Posts: 864 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
For a full race car ...YES
For a street car (occasional autox/DE) with a sound body conditon...NO |
Feb 21 2018, 09:42 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Most people who install the inner long kit seem happy with the results.
I'm probably going to do tangerine racing's suspension console reinforcement because I have it, looks cool to me and couldn't hurt. The outer suspension consoles are a weak point on our cars. |
ConeDodger |
Feb 21 2018, 09:55 PM
Apex killer! Group: Members Posts: 23,543 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have the inner long kit. It is noticeably stiffer, especially when you drive at an angle into a driveway.
The factory stiffening can be useful for cars which see a lot of track and autocross with race rubber and possibly DOT R tires. I have seen instances of the body ripping or cracking above the rear suspension mounts. This would be double thick with that kit. What your describing is not a whole long way from stock. Oh, BTW, isn’t that 2056 a great motor? (IMG:style_emoticons/default/evilgrin.gif) |
914forme |
Feb 22 2018, 06:19 PM
I would say that in reality for a street car the Maddog inners are not even needed.
Tangerine's rear console re-enforcements would be my first and only thing. I have a heavily modified 914 chassis in my EG build, Maddog inner, 914 LTD outers, Tangerine racing everything else, including the rear suspension 2" raise. Super stiff chassis. I can jack it up and lift three wheels with just 1/8" of deflection across the chassis. the 914 style roof should help get that last bit out of the equation. I ran DOT-R on this car. was planning on going to slicks for the next level. For my fathers 914-6 I have the Maddog unit if I need it. But am thinking I will only install Chris's rear suspension stuff. Though I doubt it will be needed, then I have done my fair share of replacing rear inner suspension consoles. (IMG:style_emoticons/default/dry.gif) |
EdwardBlume |
Feb 22 2018, 09:33 PM
Its all relative to where your car has been before rust wise. For a 2056, you're not going to split the chassis going around corners, unless again, the car's in used up shape to begin with...
rcarson25 |
Feb 22 2018, 09:44 PM
Thanks for all the input. Overall the car is pretty solid. I will have a little pan work to do soon but not near as bad as most driver cars I see out there. I think I may still do the mad dog inners just to get the car a little tighter feel and additional piece of mind. I haven’t gotten to dive the car with the 2056 in it yet but I am sure it will put a smile on my face. I have only driven a 1.7 914 and I didn’t want to go too crazy on this car just looking for a unique driver.
infraredcalvin |
Feb 22 2018, 10:44 PM
Distracted Member Group: Members Posts: 1,496 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
So you say it’s “in paint”. Does that mean you’ll be adding these afterwards? NO, you dont need any of that with a solid car. If you want to stiffen for spirited driving or autocross, consider a bolt in gt style hoop (rear hoop and diagonal bars to longs) like Shea’s or the one mcmark was making. Minimal paint damage that’s covered by carpet.
GeorgeRud |
Feb 23 2018, 01:33 PM
Though it does change the look of the outer long, the stiffener kit that Brad Mayeur at 914Ltd. put together does a great job of strengthening the area. It fits all the way from the rear suspension pickup points to the front of the long and I can really feel the difference between my conversion car (with his kit) and my stock 914-6. For a track car, a cage is best, but inappropriate for a street car.
Justinp71 |
Feb 23 2018, 04:54 PM
Senior Member Group: Members Posts: 1,582 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Though it does change the look of the outer long, the stiffener kit that Brad Mayeur at 914Ltd. put together does a great job of strengthening the area. It fits all the way from the rear suspension pickup points to the front of the long and I can really feel the difference between my conversion car (with his kit) and my stock 914-6. For a track car, a cage is best, but inappropriate for a street car. (IMG:style_emoticons/default/agree.gif) I have the Brad Mayeur 914 LTD kit (and rear console kit) for my mostly street car. It really helped stiffen it up. Its cool too because you can jack it up anywhere on the side of the car. It's only draw back is the extra weight. I was encouraged to install it by Rich Johnson, he thought it was the best chassis stiffening kit out there. |
sixnotfour |
Feb 23 2018, 05:05 PM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
1970 914, with added stress = inner ear reinforcement #1
larryM |
Feb 24 2018, 01:25 AM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
the stiffener kit that Brad Mayeur at 914Ltd. put together does a great job of strengthening the area. For a track car, a cage is best, but inappropriate for a street car. the best, simplest thing you can do is buy an AutoPower 914 roll bar - it will make an amazing difference in the most basic 914 "flexy-flyer" Yes - have had Mayeur kit on my car since i started racing it circa 1992 - i got it via Brad Roberts about the time he designed his own weld-on kit which others have copied, - i just "pop-riveted" Mayeur's kit on, in case i wanted it off someday - (one must purchase an expensive hydraulic riveter & large rivets to accomplish that) - my car already had the factory reinforcements but i will say the Mayuer kit added more stiffness (along with some lbs) |
Lo-Fi Version | Time is now: 28th March 2024 - 08:21 AM |
