Is there a "correct" order in which to section a car? |
Tdskip |
Feb 22 2018, 07:49 PM
While saving the good bits?
The front trunk firewall is perfect, longs and floors both perfect, need to keep the hell hole and rear clip intact as those are spoken for. Rear window glass and targa top out and off respectively it would seem. |
EdwardBlume |
Feb 22 2018, 09:26 PM
While saving the good bits? The front trunk firewall is perfect, longs and floors both perfect, need to keep the hell hole and rear clip intact as those are spoken for. Rear window glass and targa top out and off respectively it would seem. (IMG:style_emoticons/default/sawzall-smiley.gif) See what people need and what's good. You never really know what goes bad on people's cars.... |
gms |
Feb 23 2018, 05:24 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I cut the front floor then the rear floor leaving a floor section
I usually start cutting outside the longitudinal (not shown in this picture) you can then take the front piece and rear piece to the scrapper they are very manageable weight wise. If you still need to make it smaller you can then cut the front and rear in half the rear clip will stand up by itself for you to cut |
gms |
Feb 23 2018, 05:34 PM
Tdskip |
Feb 24 2018, 08:16 AM
Thank you Gene.
Lo-Fi Version | Time is now: 7th May 2024 - 01:12 AM |
