6 conversion voltage reg |
Evill Ed |
Jun 3 2005, 05:14 AM
Member Group: Members Posts: 238 Joined: 28-February 03 Member No.: 371 Region Association: None |
I'm putting a 1980 3.0L engine in a 914. There is a 3 prong plug for the voltage regulator on the engine harness. Can I just plug in the regulator from the old 4 cylinder relay board or use a generic solid state type? I am not using the relay board from the 4.
Thanks, Ed |
Kerrys914 |
Jun 3 2005, 05:24 AM
Good Q (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I have asked the same questions and situation ( (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) minus the 3.0L) and what I was told by the board was it will/might/don't know. A vendor (GPR) told me to just use the 4 cyl since a VR is a VR is a VR. My engine will be running in a week or so, I will let you know how it turns out. |
iamchappy |
Jun 3 2005, 06:34 AM
You might want to check if the 6 alternator has an internal regulator in it already my 79 did. Otherwise the four should work fine.
Evill Ed |
Jun 3 2005, 09:44 AM
This am what it look like on the back. It's not internally regulated, is it?
Ed Attached image(s) |
Kerrys914 |
Jun 3 2005, 10:00 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Nope you need an external VR
ejm |
Jun 3 2005, 10:29 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Besides the B+ and ground you need three other wires with an external regulator...don't see them in the pic
Evill Ed |
Jun 3 2005, 10:47 AM
Ed, the engine has the factory wiring harness on it. There is a plug, 3 prong, for the regulator. Are those the wires you are referring to? Or are there suppossed to be more wires on the back of the alternator?
Ed |
Kerrys914 |
Jun 3 2005, 10:57 AM
IIRC
The fat red wires go to the starter. The other three (3- wires) go to the VR Cheers (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) I ws looking at your photo and have a question (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Is the wire to the brushes just wrapped around the spade connector (Missing the female connector)? |
Evill Ed |
Jun 3 2005, 11:19 AM
I put a connector on it, when the engine arrived it didn't have one. Good eye (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Ed |
Lo-Fi Version | Time is now: 11th June 2024 - 03:24 PM |
