V-8 conversion, still can't shake temptation |
chrisg |
Feb 23 2018, 09:52 PM
Member Group: Members Posts: 63 Joined: 20-December 03 From: Paso Robles, CA Member No.: 1,455 Region Association: None |
Probably typical story, but I've had my 914 for quite some time now. I haven't driven my 914 for quite some time now do to the pipe dream of restoring/freshening it up, and then way too much other crap getting on the way. But I'm really trying to make this the year I start the endeavor.
I keep coming back to being tempted into doing a V-8 conversion even after twice as many times of talking myself into leaving it a type 4. Problem #1: I'm just not in love with the VW motor or the cost of having a stout one built. Problem #2: I've never come across a thread post where a V-8 conversion owner is disappointed in having done it. They seem to always come to the same consensus that it is a reasonably painless swap, reliable, and very enjoyable end result. Appeals: effortless torque, reliability, aural bliss (second only to an almighty -6), affordability My thinking is that since I'm going to go through the whole car anyway (with a much desired 5 lug conversion) doing it to accommodate a (mild) V-8 swap, shouldn't be going off the deep end. And, it would kind of kill two birds with one stone and allow me to have a retro Porsche that handles well and is still light weight and a V-8 all wrapped up in one. The point of this post? I'm still not convinced that it's not a "bull in a china shop". Does it retain the proper character of something you want to drive fast and have fun with on twisty back roads? Is the balance thrown off at all? Or should I just stop wasting my time going back and forth and commit to doing it? |
dwillouby |
Feb 24 2018, 10:16 AM
Member Group: Members Posts: 392 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Not to hijack the thread but if you decide the V8. I will soon have some parts for sale.
Going to a boxster 6 speed. Will be selling 1. 901 side shift transaxle flipped 3,4th, 1st removed and locked out, H-5th with 106 mm flanges 2. SBC to 901 adapter plate, flywheel, stage 2 clutch & p plate. 3. IMI high torque starter 4. extended shift rod 5. trans setback mounts $800.00 plus shipping Will be posting in for sale section soon Thanks David |
Mueller |
Feb 24 2018, 02:35 PM
Not to hijack the thread but if you decide the V8. I will soon have some parts for sale. Going to a boxster 6 speed. Will be selling 1. 901 side shift transaxle flipped 3,4th, 1st removed and locked out, H-5th with 106 mm flanges 2. SBC to 901 adapter plate, flywheel, stage 2 clutch & p plate. 3. IMI high torque starter 4. extended shift rod 5. trans setback mounts $800.00 plus shipping Will be posting in for sale section soon Thanks David That would work with a Chevy 4.3 V6 correct? I think that would be good choice as well. Seen a few and the fit is near perfect due to the shorter block. |
BIGKAT_83 |
Feb 24 2018, 02:54 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Not to hijack the thread but if you decide the V8. I will soon have some parts for sale. Going to a boxster 6 speed. Will be selling 1. 901 side shift transaxle flipped 3,4th, 1st removed and locked out, H-5th with 106 mm flanges 2. SBC to 901 adapter plate, flywheel, stage 2 clutch & p plate. 3. IMI high torque starter 4. extended shift rod 5. trans setback mounts $800.00 plus shipping Will be posting in for sale section soon Thanks David That would work with a Chevy 4.3 V6 correct? I think that would be good choice as well. Seen a few and the fit is near perfect due to the shorter block. It will if its for a 86 or newer SBC with a one peace rear main bearing seal. The Flywheels changed to a different bolt pattern with the change in 86. I think all 4.3 v6 have the newer bolt pattern. |
Lo-Fi Version | Time is now: 26th May 2024 - 06:15 AM |
