WTB: Auxiliary Air Regulator -Part# 022906045, 1973 2.0 — Last part needed ... really this is the last :)! |
Jett |
Feb 23 2018, 11:48 PM
Senior Member Group: Members Posts: 1,632 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
After a three year restoration, our 1973 2.0 had its first tune today (IMG:style_emoticons/default/smile.gif). That said, the last remaining problem is that the air bypass valve for the high idle when cold is not shutting off. So the idle sticks high. Its getting power so we think it has to be the valve?
Does anyone have an auxiliary air regulator for sale? Thanks |
914Sixer |
Feb 24 2018, 07:58 AM
914 Guru Group: Members Posts: 8,867 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Might try shooting some PB Blaster and letting it set for a while. May free it up.
Feb 24 2018, 08:19 AM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have this one. PM me your address. I'll send it out. If you are happy with it and it works, you can send me $50.
JOEPROPER |
Feb 24 2018, 08:38 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Feb 24 2018, 09:12 AM
I have this one. PM me your address. I'll send it out. If you are happy with it and it works, you can send me $50. Mark, do you have the elbow that goes on the other end? Doesn't the other end get a straight piece of hose directly to the manifold. I don't remember..... |
JOEPROPER |
Feb 24 2018, 09:50 AM
I have this one. PM me your address. I'll send it out. If you are happy with it and it works, you can send me $50. Mark, do you have the elbow that goes on the other end? Doesn't the other end get a straight piece of hose directly to the manifold. I don't remember..... I think there is an elbow at the top port. I've seen pictures of it, but this is a project that I didn't take apart. |
Jett |
Feb 24 2018, 10:49 AM
MikeInMunich |
Feb 26 2018, 11:17 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
I have this one. PM me your address. I'll send it out. If you are happy with it and it works, you can send me $50. Mark, do you have the elbow that goes on the other end? Doesn't the other end get a straight piece of hose directly to the manifold. I don't remember..... I think there is an elbow at the top port. I've seen pictures of it, but this is a project that I didn't take apart. That "elbow" is rubber and isn't typically with an AAR valve. Perhaps it's connected to the intake on the engine? If you don't have it there it may be on your own AAR which is apparently defective(?). Otherwise, it's missing. Good luck finding it! |
Mikey914 |
Feb 27 2018, 10:29 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Goes to the manifold.
We made the elbow Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 12:59 AM |
