Black paint options for top of 914, flat vs textured surface |
My 914 |
Feb 24 2018, 06:32 AM
Casual Member Group: Members Posts: 560 Joined: 23-April 16 From: Massachusetts Member No.: 19,928 Region Association: North East States |
I have been thinking about repainting the top of my car and have seen tops with a flat black smooth finish and others with a textured finish. Were both original options and is there any advantage of one vs the other or is it more of a personal preference?
Thanks for any input/suggestions |
Tom_T |
Feb 24 2018, 10:39 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
I have been thinking about repainting the top of my car and have seen tops with a flat black smooth finish and others with a textured finish. Were both original options and is there any advantage of one vs the other or is it more of a personal preference? Thanks for any input/suggestions For anyone trying to do an originality restoration, they should do it as per the factory. Otherwise it's a matter of preference. One advantage to the texture, is that it hides the flaws in the the fiberglass used for the top which would need to be first finished to dead smooth - which takes time, patience & skill (ask any 'Vette owner about body work). To answer your question on how they came - they all came from the factory with the same textured finish & satin black paint, the same as used on the F & R Valances, & L & R Rocker Covers - & on the 73-74 MY only, on the black painted steel F & R Bumpers (IIRC the steel roofs of the factory racers 914-6GT were smooth painted). Everything else from smooth black, to body color are repaints by later owners. You can just top coat the textured top, if it's still in good shape. If you want to do yours as original, there is a topic or a few in the O&H Forum on using Wurth Underbody Schutz & satin black paint. Use google search to find it, since the search function on here doesn't work as well. Also try out your techniques for the texture & top paint on some scrap metal, coated cardboard or something first, in order to get it down before doing the parts. A house painter or Architect would call the texture a "heavy eggshell finish". If your Valences, Rockers &/or Bumpers also need some TLC, then do them all together. On your 73 V8 conversion you can also do whatever else you want, since it's not an originality resto, but a resto-mod anyway. (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 15th May 2024 - 04:04 PM |
