Stock grind camshaft brand, What is decent |
mihai914 |
Feb 24 2018, 11:24 AM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Hi to all,
I'm getting ready to have the original 2.0 rebuilt. The only mod will be some Euro Kolbenschmidt P&Cs. Everything else will be stock. I will keep the D-jet. I have my parts li$$$t ready and the only thing I am having difficulty making a choice is on the camshaft and lifter combo. I searched the forum and most posts refer to cam choices for carbed engines or 2056, with Raby cams (9550) and WebCams (73) highly regarded. There just isn't that much info on stock grind and there even is doubt on the specs from different vendors. Major vendors who offer stock cams are EMW, Scat, CBPerformance, Type4store, WebCam and Pelican. Prices vary from $200 to $1000. Anyone have recommandations or should I just go with a factory cam from Pelican with the Febi lifters? Thanks for your help. |
worn |
Feb 24 2018, 11:35 AM
can't remember Group: Members Posts: 3,145 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Thanks for posting this. I think I would have been better off with a stock cam in my 2056, but ended up with a Raby-style cam from WebCam. I think it is very high quality, but harder to manage with the stock FI. Finding stock cams was surprisingly hard. In retrospect I think I should have sent my cam off for a regrind.
dr914@autoatlanta.com |
Feb 24 2018, 03:55 PM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
webcam makes a nicely stock cam for 914 fuel injection.
Hi to all, I'm getting ready to have the original 2.0 rebuilt. The only mod will be some Euro Kolbenschmidt P&Cs. Everything else will be stock. I will keep the D-jet. I have my parts li$$$t ready and the only thing I am having difficulty making a choice is on the camshaft and lifter combo. I searched the forum and most posts refer to cam choices for carbed engines or 2056, with Raby cams (9550) and WebCams (73) highly regarded. There just isn't that much info on stock grind and there even is doubt on the specs from different vendors. Major vendors who offer stock cams are EMW, Scat, CBPerformance, Type4store, WebCam and Pelican. Prices vary from $200 to $1000. Anyone have recommandations or should I just go with a factory cam from Pelican with the Febi lifters? Thanks for your help. |
914_7T3 |
Feb 24 2018, 05:03 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Hi to all, I'm getting ready to have the original 2.0 rebuilt. The only mod will be some Euro Kolbenschmidt P&Cs. Everything else will be stock. I will keep the D-jet. I have my parts li$$$t ready and the only thing I am having difficulty making a choice is on the camshaft and lifter combo. I searched the forum and most posts refer to cam choices for carbed engines or 2056, with Raby cams (9550) and WebCams (73) highly regarded. There just isn't that much info on stock grind and there even is doubt on the specs from different vendors. Major vendors who offer stock cams are EMW, Scat, CBPerformance, Type4store, WebCam and Pelican. Prices vary from $200 to $1000. Anyone have recommandations or should I just go with a factory cam from Pelican with the Febi lifters? Thanks for your help. I had the same problem, but was able to source a NOS VW Camshaft and lifters right in the middle of your price range noted. I am using a set of 96mm P&Cs for a 2056 with original D Jet as well. If you have the time and search the net using the correct Porsche/VW part #s you may be able to find exactly what you need. I did the same for the internals of my 901 transmission rebuild with the same result. Its still out there if you look hard enough. |
914Sixer |
Feb 24 2018, 08:01 PM
914 Guru Group: Members Posts: 8,869 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Send your cam to Elgin Camshafts. Go to their website and look at your choices.
jcd914 |
Feb 24 2018, 11:22 PM
Elgin has a grind that is a slight improvement over stock without messing with the stock fuel injection Jim |
mihai914 |
Feb 25 2018, 06:15 AM
Thank you to all for your input. I think I will send the best camshaft I have laying around to Elgin and see what they can do with it. I'll give them a call on Monday to see what they recommend for the lifters.
By the time the engine will be ready for reassembly, I may get lucky and find a NOS combo and use the rebuilt on the next engine he build. |
saigon71 |
Feb 25 2018, 11:30 AM
Senior Member Group: Members Posts: 1,997 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I don't think you can go wrong with Elgin.
I went with a FAT cam & lifters. They have a bone stock grind available, but also have a slightly more aggressive grind (the 440MP) that works well with the factory FI. |
914_7T3 |
Feb 25 2018, 12:29 PM
Thank you to all for your input. I think I will send the best camshaft I have laying around to Elgin and see what they can do with it. I'll give them a call on Monday to see what they recommend for the lifters. By the time the engine will be ready for reassembly, I may get lucky and find a NOS combo and use the rebuilt on the next engine he build. Try German Supply in Toronto for the lifters and Bug City in CT. For lifters and Cam. That’s where I found mine. Good luck! |
Lo-Fi Version | Time is now: 25th April 2024 - 02:44 AM |
