Renn shift, Bad shifting |
cal914 |
Feb 24 2018, 11:57 AM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
Picked up our 914-6 GT Replica today after an engine rebuild ,can’t get the car into 1st or reverse with out crunching ,the rest of the gears are really really stif to get into the remaining gears,I bought the linkage set up that was recommended for the car at the same time ,does anyone else have a renn shifter on there 6 cylinder and does it run smooth or do you have problems ,please tell me there’s an easy fix,it’s so frustrating
Thanks Brian |
Feb 24 2018, 12:14 PM
Resident German Group: Admin Posts: 41,603 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have a Rennshift on my car and it works just as advertised.
The key is to take your time when you adjust the linkage to get it just right. That has nothing to do with the Rennshift though, it's the same for the stock shifter. (IMG:style_emoticons/default/shades.gif) |
defianty |
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
Brian, it'll be an easy fix. It just needs adjusting as the linkage has been disturbed during the engine refit.
Feb 24 2018, 01:38 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Also make sure the clutch cable is adjusted properly.
RickS |
Feb 24 2018, 01:52 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Brian, it'll be an easy fix. It just needs adjusting as the linkage has been disturbed during the engine refit. Anyone game to come over and “easy fix” mine? Have fooled with it incrementaly and systematically for four hours and a fix to one area causes a new problem. I need an intervention before I send it sailing into the woods. |
Feb 24 2018, 05:05 PM
Brian, it'll be an easy fix. It just needs adjusting as the linkage has been disturbed during the engine refit. Anyone game to come over and “easy fix” mine? Have fooled with it incrementaly and systematically for four hours and a fix to one area causes a new problem. I need an intervention before I send it sailing into the woods. It took me 5 minutes to set mine. Make sure there isn’t anything rubbing or binding in the tunnel (or anywhere else) and all the clamps and set screws are tight. I set both the shifter and trans into 2nd gear and tightened the bolt. Mine was a little difficult to get into gear, I adjusted some slack out of the clutch cable and then it moved easily. A rennshifter just duplicates the stock shifter but has no slop at the shifter. It really can’t make the shifting worse. Every thread I’ve read that mentions an issue with a rennshifter turns out to be something else. Loose cone screw, interference in the tunnel, ect. |
ejm |
Feb 24 2018, 07:17 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,689 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
JmuRiz |
Feb 24 2018, 08:07 PM
914 Guru Group: Members Posts: 5,422 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Also make sure the clutch cable is adjusted properly. (IMG:style_emoticons/default/agree.gif) my car had that issue once, clutch adjustment made it good as new. Need to do the same thing now on the 911 |
RickS |
Feb 24 2018, 08:22 PM
Brian, it'll be an easy fix. It just needs adjusting as the linkage has been disturbed during the engine refit. Anyone game to come over and “easy fix” mine? Have fooled with it incrementaly and systematically for four hours and a fix to one area causes a new problem. I need an intervention before I send it sailing into the woods. It took me 5 minutes to set mine. Make sure there isn’t anything rubbing or binding in the tunnel (or anywhere else) and all the clamps and set screws are tight. I set both the shifter and trans into 2nd gear and tightened the bolt. Mine was a little difficult to get into gear, I adjusted some slack out of the clutch cable and then it moved easily. A rennshifter just duplicates the stock shifter but has no slop at the shifter. It really can’t make the shifting worse. Every thread I’ve read that mentions an issue with a rennshifter turns out to be something else. Loose cone screw, interference in the tunnel, ect. Good advice. It probably IS something else since shifting has never been effortless. Will have to go through the whole system. Thanks |
Feb 24 2018, 08:38 PM
Try a couple turns on the clutch cable nut at the pulley. It made a huge difference on my car.
cal914 |
Feb 25 2018, 01:05 PM
It was the clutch that needed adjusting. An easy fix for expert Kevin Clarke, within an hour. Its now as sweet and silent as anything. Incredible. Now the fun can start !!!
rhodyguy |
Feb 25 2018, 01:39 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
BRILLIANT!
Feb 25 2018, 02:31 PM
Or it might be the clutch. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 23rd April 2024 - 03:41 AM |
