What is this undercoating material, Not your normal rubber stuff |
Mikey914 |
Feb 25 2018, 01:13 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So cleaning up the bottom of the car to assess the entire car, and found this material that looks like a light coat of primer. It has enough grime on it to be original.
My question to anyone that was around when these were coming out of the dealerships is; what is it, and what was it supposed to do? There is no rust so it certainly worked, but this was a Nevada car all its life. Mr Mayer perhaps you have an idea? Attached thumbnail(s) |
Mikey914 |
Feb 25 2018, 02:48 PM
Thanks Andy,
Definitely has a different texture. It doesn't seen to be a faded paint underneath, as its pretty uniform. My inpression is that it may have the PVC base coat, but also has a coating over the paint. I did try removing it in a small section and was able to het more color to show with a solvent. Mt search now is for the original material it was coared with on tbe outside. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:29 AM |
