914/6 fuel line question |
Tdskip |
Feb 25 2018, 01:52 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Happy Sunday to you all.
Standard fuel lines on a 1974 OK for a 3.0 L CIS system? Do I need to be doing anything special on the wines or part of the standard steel ones in the car OK? Thanks! |
Feb 25 2018, 02:29 PM
Steel ones are perfect. If you had some fire breathing carbed motor it might be different but cis won’t suck down the fuel.
Tdskip |
Feb 25 2018, 05:55 PM
Thank you
ChrisFoley |
Feb 26 2018, 07:39 AM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Happy Sunday to you all. Standard fuel lines on a 1974 OK for a 3.0 L CIS system? Do I need to be doing anything special on the wines or part of the standard steel ones in the car OK? Thanks! THe stock '73 fuel lines in the tunnel are not made to take the high pressure that a fuel injection pump puts out. If you relocate the pump to the front of the car you should definitely replace the tunnel lines. |
Lo-Fi Version | Time is now: 25th April 2024 - 03:53 PM |
