How to Remove Cup from Ball Pin, Sideshift 901 |
motorvated |
Feb 25 2018, 07:48 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
I've seen threads that mention that the plastic cup snaps onto the ball of the ball pin, but how does one remove it without breaking it? I need to transfer it to another tranny, but I don't know exactly how to pry if off the existing tranny without damaging it. Did a search, but found nothing.
GeorgeRud |
Feb 25 2018, 07:53 PM
If it can be arranged, heating it in some hot water can soften some of this plastic, but it may be easiest to just purchase another one.
Feb 25 2018, 08:34 PM
I am lost
What is a ball pin? All the plastic bushings will come out and can be transferred. |
motorvated |
Feb 25 2018, 08:53 PM
I am lost What is a ball pin? All the plastic bushings will come out and can be transferred. The ball pin is the metal arm with the large ball on the end of it that is attached to the shaft that exits the transaxle housing inside the shift console. There is a plastic cup that apparently snaps over the ball and then there is a metal sleeve with cone screw that slips over the plastic cup and connects the long shift bar that goes forward through the rear console and continues forward to the firewall bushing. |
Mikey914 |
Feb 25 2018, 09:16 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Hot water works, but if yhere is any wear or deformation you can get slop. At $3.20 why risk doi g the job 2x.
http://shop.914rubber.com/91142413900-Ball...m?categoryId=-1 |
Tdskip |
Feb 25 2018, 09:24 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hot water works, but if yhere is any wear or deformation you can get slop. At $3.20 why risk doi g the job 2x. http://shop.914rubber.com/91142413900-Ball...m?categoryId=-1 +100 |
rgalla9146 |
Feb 25 2018, 09:54 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Use an open end wrench to lever it off.
You'll have to cobble a fulcrum. If it survives..... buy a spare anyway Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:48 PM |
