I had a case of the DUMB ASS |
spare time toys |
Jun 3 2005, 11:21 AM
Way back when in DesMonines When we did the cut to the trans. Rick and I noticed the when you spun one of the axel output flanges the other went the same way and you could not hold it. So Im out in the dog house today and get the bright idea to take the side cover off and see if it is posi or welded. This is where the dumb ass comes in... I grab the impact so I can zip the bolts off and forgot to put in in reverse. (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) You know the bolt that holds the flange on (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) it snaps off real quick (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/alfred.gif)
spare time toys |
Jun 3 2005, 11:22 AM
I got the cover off with no further F/., ups and found the spiders are welded
spare time toys |
Jun 3 2005, 11:24 AM
I counted pinion teeth 7 and ring 32 that gives a 4.57 it should be OK for a V8 dont you think?
Aaron Cox |
Jun 3 2005, 11:27 AM
SHOULD be a 7:31
URY914 |
Jun 3 2005, 11:29 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Larry, Larry, Larry,....
You're supostwo spin the motor to see which way it's turning BEFORE you put it on the bolt. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Paul |
Joe Bob |
Jun 3 2005, 11:33 AM
Could be worse.....it coulda busted off where you needed to drill/tap and/or ez out it....count yer blessings.
Accentuate the positives and deal with the negatives.... REPEAT after me.....hey the beer is here....little warm but better than NO BEER....see it's EZ....OOOoooohhhhmmmmm, there's girls on the beach.....they're not REALLY gud looking and I'm married but it's better than thinking of Miles nekkid..... OK...BAD example.... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
ewdysar |
Jun 3 2005, 11:35 AM
What happens here, stays here. Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 |
If it's a 901, the R&P should be 7:31 - 4.42 A V8 has no problem pulling all the gears, even if the gears have been swapped out to tall ratios, swap and flip 3 and 4, H gear for 5. If it's an AX or track car the close ratios might be OK, but taller gears will cut down on your shifting. My 327 daily driver with a tall gear 901 and 205/50/15 turns 2750 RPM @ 70 MPH, I'm working on getting the engine speed even farther down i.e. taller tires.
spare time toys |
Jun 3 2005, 11:37 AM
I spun the trans and one turn of the ring took just short of 5 turns on the pinion. Remember all this was done in the early 70s so who knows what gears are inside this thing? |
Aaron Cox |
Jun 3 2005, 12:59 PM
no 7:32 available....
there is a 7:31 and one other option....chris foley has it in his FP race car. |
ewdysar |
Jun 3 2005, 01:04 PM
Oooh! Ooooh! Tell us about the double secret 901 R&P option... (we promise not to tell (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) )
Eric |
Aaron Cox |
Jun 3 2005, 01:19 PM
yeah yeah - you could get a 7:27 in a sportomatic... ask mr foley. he has a different ratio in his race car... |
Joe Bob |
Jun 3 2005, 01:45 PM
HEY...this IS Friday....how about a bit of levity.....?
Lo-Fi Version | Time is now: 12th June 2024 - 12:00 AM |
