GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
markhoward |
Feb 28 2018, 10:02 AM
Member Group: Members Posts: 374 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
I'm in for a std.
morgan_harwell |
Feb 28 2018, 10:23 AM
Ha! Finally snuck up on a camera! Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
I'm in for one, standard 4 length.
My Six-Conversion uses stock 4-cylinder throttle cables. I changed the throttle plate, that mounts on the top of the 911 case, to accept a throttle cable that pulls from the front. |
green914 |
Feb 28 2018, 10:41 AM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
I will take one.
walterolin |
Feb 28 2018, 11:51 AM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
One.
1.7 stock FI, early. |
brant |
Feb 28 2018, 11:53 AM
914 Wizard Group: Members Posts: 11,584 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I had better put my name down n the list
Thanks! |
913B |
Feb 28 2018, 12:43 PM
Senior Member Group: Members Posts: 842 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Sign me up for one (IMG:style_emoticons/default/biggrin.gif)
Rleog |
Feb 28 2018, 01:29 PM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
One
Mikey914 |
Feb 28 2018, 02:45 PM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
EVERY carbed v8 conversion could use this.. The throttle cable has to be put to such a tight angle that they snap pretty often Sadly I am drive by wire now so I cant use this... (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/agree.gif) And there are enough of them to make it worthwhile. A cable for Subaru conversions would be nice as well. IIRC. the cable required for the Subaru is the same as stock except the sheathing is cut 6" shorter and cable was 6" longer. (IMG:style_emoticons/default/confused24.gif) This can easily be done at this point. Maybe add as an option if you want to show the routing for others. Mark |
Mike D. |
Feb 28 2018, 04:30 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,444 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I'd be in for 2!
Luke M |
Feb 28 2018, 05:12 PM
Senior Member Group: Members Posts: 1,366 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I'd be in for 4 cables as long as they fit a factory 6 .
Keep us posted. |
Mikey914 |
Feb 28 2018, 05:47 PM
I can make the 6 cables and if the fittings are all the same (and I suspect they are), the cost would be the same and help contribute to the count.
Mblizzard |
Feb 28 2018, 07:16 PM
My credit card hates you. But my car loves you. I am in for one.
turnaround89 |
Feb 28 2018, 08:25 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I'd be in for a custom one for my Subaru conversion
maf914 |
Mar 1 2018, 06:47 AM
Mark, add me to the list for a stock four cable. Thanks as always.
73-914 |
Mar 1 2018, 07:18 AM
Senior Member Group: Members Posts: 556 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None |
in for 2 PLZ 73 4cylinder Carbed
JamesM |
Mar 1 2018, 10:42 AM
Senior Member Group: Members Posts: 1,872 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Im in.
rgolia |
Mar 1 2018, 10:44 AM
GeoJoe Group: Members Posts: 702 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
Ill take one.
jim_hoyland |
Mar 1 2018, 01:04 PM
Get that VIN ? Group: Members Posts: 9,225 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
An improved accelerator cable is a great idea for a new product; the scariest feeling is to have that cable break while in traffic or any other situation where it’s gonna take gas to get onto a safe spot. And even then, you have to tow....
Luke M |
Mar 1 2018, 01:09 PM
Hi Mark,
Here's the 914-6 cable pics and info we pm'd about. over all length is : 99 1/4'' from end to end the sheathing is : 41 3/4'' from end to end the metal threaded part that mounts on the trans bracket is : 55 mm from end to end the pedal and trans threaded ends for the cup/ball socket is : 38 mm from end to end cable thickness is 2 mm and has a plastic coating on the cable itself. The pics of the 6 trans and carb manifolds are so you get an idea on how the cable mounts/runs. Let me know if you need more info. Luke Attached image(s) |
restore2seater |
Mar 1 2018, 01:14 PM
Future 914 copilot. Group: Members Posts: 311 Joined: 30-October 04 From: Dunlap,IL Member No.: 3,037 Region Association: None |
I'm in for a cable on a -6.
Lo-Fi Version | Time is now: 28th March 2024 - 02:41 PM |
