GB for throttle cable improved $24 will be $32 after (pics post 153), These are on 6.19.19 Will honor GB price but after will be more |
porschetub |
Mar 1 2018, 01:18 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Stainless cable runs a lot less friction and feels much smoother,made one for my Speedster replica and found my Webers snapped closed without the need of a centre return spring which previously caused a heavy pedal with the stock (cut down) cable.
Top marks 914rubber (IMG:style_emoticons/default/smilie_pokal.gif) . |
Wayne |
Mar 1 2018, 01:21 PM
SoCal-Bumblebee Group: Members Posts: 47 Joined: 29-January 16 From: Orange County, CA Member No.: 19,612 Region Association: Southern California |
I'm in for one. Thanks Mark
Mikey914 |
Mar 1 2018, 07:12 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
FOR THE 6 -
Good news is the bellows I already make. It can be included easily. The trans end is different but can be easily made. It will cost a few bucks more, but not much.I need to figure out how much, but my guess is it would add $5. Mark |
FL000 |
Mar 1 2018, 08:48 PM
Member Group: Members Posts: 387 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I’m in for one. Thanks as always.
don-6 |
Mar 1 2018, 09:58 PM
Stock vs Modified? Group: Members Posts: 172 Joined: 7-April 14 From: Conroe, TX Member No.: 17,219 Region Association: Southwest Region |
One -6 cable.
jesse7flying |
Mar 2 2018, 09:17 AM
Member Group: Members Posts: 134 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None |
One -4 cable please.
RickS |
Mar 2 2018, 11:30 AM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Add one for a converted 6. Thanks
djway |
Mar 2 2018, 05:57 PM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Dos Cabelos PorFavor
RickS |
Mar 2 2018, 08:48 PM
Dos Cabelos PorFavor Cabelo is hair in Portuguese. Two hairs please (IMG:style_emoticons/default/biggrin.gif) |
914four |
Mar 3 2018, 09:14 AM
Senior Member Group: Members Posts: 510 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States |
One cable please.
CMONNETT |
Mar 3 2018, 09:23 AM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
Ill take 2 4cyl cables.
Mikey914 |
Mar 3 2018, 10:34 AM
Judging from the interest I will be moving forward on these this next week.
We will do the stock cable 4 6 cable to factory spec V8 cable - using factory terminations Subaru cable - using factory terminations They will all be at the same price except the 6 which is different and will require more machining. It will be $29. After the GB the V8 and Subaru will be more but we will stock a few. |
stevend914 |
Mar 4 2018, 06:22 AM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
I'll take two for a stock 4 cyl
michael7810 |
Mar 4 2018, 07:42 AM
Senior Member Group: Members Posts: 1,078 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
One of my 4s is carbbed and using a stock cable. I can do 3 versions, dtock 4, a predetermined 6 conversion, and custom to customer spec. The 3rd bersion, will be more expensive if we do it in the future, but in production its easily accomidated. Does anyone know if a longer than stock cable can be used on a carbed 4 to allow routing the cable through the stock location in the engine tin? It's been decades since I hooked up a throttle cable to carbs and don't remember how I did it, and I was less picky back then about how I did things. I'm completely ignorant about options and what a custom spec cable would look like for this application. I didn't like the way the stock cable fit my carb'ed car so I made a custom cable using motorcycle cable and bicycle brake cable housing. I used a cutoff bolt, center drilled for the accelerator pedal end but the carb end was just cable (not optimal but it's been working for 5+ years with several removal/reinstalls. My cable attaches to the backside of the carb by #1 cylinder and at the stock cable was just too short. It would work but the angles were severe. Now it has nice smooth arches and is buttery smooth. My custom cable is 115.5" long including the 1-1/4" bolt swedged on the end. I should have made 2 for a spare but didn't. I recently removed it and it shows no sign of wear or damage so it should be good for a while. |
Halfnelson |
Mar 4 2018, 10:26 AM
Newbie Group: Members Posts: 43 Joined: 31-July 17 From: Cornwall Member No.: 21,303 Region Association: England |
I'll take one for 1.8 standard. Do you do clutch cable as may combine for UK postage?
Cheers Chris |
Mikey914 |
Mar 4 2018, 11:20 AM
I have yet to make the clutch, but I do plan to go there. I have the commercially available German ones in stock
flmont |
Mar 4 2018, 11:44 AM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Ill take 1 also
Halfnelson |
Mar 4 2018, 11:47 AM
02loftsmoor |
Mar 4 2018, 01:18 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
We are looking at making an improved version of the throttle cable utilizing 1/8" stainless cable. we will be using the architectural cable we use in the railing systems with a 1500 lb load rating. There has been some issue with fatigue on some of the cables currently on the market. If there's enough interest we can easily make these with this more rugged cable. Who's in? I'm in |
Mikey914 |
Mar 4 2018, 01:23 PM
Looks like I'm turning metal this next week.
Mark |
Lo-Fi Version | Time is now: 18th April 2024 - 10:48 PM |
