2.0 L race engine deck height, How little dare I? |
Driver174 |
Mar 7 2018, 01:02 AM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
914-4, stock crankshaft, Stock Jugs, H-Beam rods, JE Pistons, 7k redline; how tight can I safely go? I've heard that a deck height of 0.050" is a safe amount. Can I go 0.040" without risking interference issues?
Thanks, Jim |
Mblizzard |
Mar 7 2018, 07:50 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Others may have more specific information but I would be concerned about interference caused by valve float at 7K especially if you are running stock springs.
You can certainly go through the process of checking the clearance using clay or dial indicator but you also have to account for piston rock and allow additional clearance on the exhaust site for the additional expansion of the exhaust valve due to the heat. Some of the experts may be abele to give you exact numbers for rules of thumb clearances but if you are running stock springs at 7K rpm then you can be sure that you will get valve float. |
Driver174 |
Mar 7 2018, 10:55 AM
I'm really just concerned with deck clearance; wanting to know how tight I can safely go.
Valves, springs and cam have all been upgraded. Thanks, |
ChrisFoley |
Mar 7 2018, 11:02 AM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
With CrMo rods and forged pistons you can set the deck to .040" safely.
As tight as .032" is even possible without problems. The valves should get no closer than .080" to eyebrows cut in the pistons. |
Mblizzard |
Mar 7 2018, 11:21 AM
I read here somewhere that the deck height requirement was greater than ~0.028 which keeps the piston from hitting the flat portion of the head when the pistons reach max temp.
That seems pretty close to what Chris said. Attached is a file I got from someone here on calculating shim size and compression ratios that may or may not be useful. Compression.xls ( 7.49k ) Number of downloads: 179 |
yeahmag |
Mar 9 2018, 11:03 AM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I’m around 0.038” on stock 2L rods and crank, 96mm pistons, and a 7250 rpm rev limit. I do have valve pockets in the pistons and the valve train to support the rpm.
ChrisFoley |
Mar 9 2018, 11:20 AM
yeahmag |
Mar 9 2018, 11:47 AM
Not sure if you remember Evan Fullerton, but he ran stock rods to 8000 RPM! I plan to scope the motor (back side of valves and pistons) here pretty soon, just for fun really. I'll let you know if I see anything.
brilliantrot |
Mar 14 2018, 01:05 PM
Member Group: Members Posts: 125 Joined: 27-April 07 From: Costa Mesa Ca. Member No.: 7,699 |
Not sure if you remember Evan Fullerton, but he ran stock rods to 8000 RPM! But I have no idea what the deck height measurement was as FAT built the motor (8.6-1 compression on AA 96mm pistons so clearly not pushing any boundaries) and being strictly an AX car it only saw 7500+ for maybe 5 seconds or less a run in 2nd and sometimes 3rd gears. What sorta works for AX, isn't something that will hold together on a track car and it certainly wasn't making power up there, just saved a shift and was faster then banging off the limiter. Truth be told, I just disabled the revlimiter entirely after I got tired of hitting it when it was set to 7500 so I really don't know what it rev'd to as I just held the pedal down until I had to slow down. The tach only is enumerated to 7k so lets just call it high RPM. I got 2 seasons of AX out of the car before selling it and it still ran great and had maybe 6k street miles on it so it was at least somewhat reliable. |
Driver174 |
Mar 15 2018, 09:58 PM
Thanks for the input guys; I'm feeling better about the .040 clearance now!
Charles Freeborn |
Jan 27 2022, 05:32 PM
Member Group: Members Posts: 244 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Ressurecting this thread as I'm unable to run the spreadsheet (for some reason my mac doesn't like the .xls file) to calculate shims / compression ratio change. In short I want to reduce the compression of an engine from 12:1 or thereabouts to closer to 10:1.
Thanks. |
stownsen914 |
Jan 28 2022, 07:58 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Ressurecting this thread as I'm unable to run the spreadsheet (for some reason my mac doesn't like the .xls file) to calculate shims / compression ratio change. In short I want to reduce the compression of an engine from 12:1 or thereabouts to closer to 10:1. Thanks. I'll be curious what folks say about type 4 motors, but I know for 911s you don't want to have a deck height more than .060". Better to reduce compression in the dome rather than at the perimeter of the piston. Shimming to reduce compression does the latter, of course. |
Lo-Fi Version | Time is now: 28th April 2024 - 11:51 PM |
