2.0 L race engine deck height, How little dare I? |
Driver174 |
Mar 7 2018, 01:02 AM
Member Group: Members Posts: 106 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None |
914-4, stock crankshaft, Stock Jugs, H-Beam rods, JE Pistons, 7k redline; how tight can I safely go? I've heard that a deck height of 0.050" is a safe amount. Can I go 0.040" without risking interference issues?
Thanks, Jim |
Charles Freeborn |
Jan 27 2022, 05:32 PM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Ressurecting this thread as I'm unable to run the spreadsheet (for some reason my mac doesn't like the .xls file) to calculate shims / compression ratio change. In short I want to reduce the compression of an engine from 12:1 or thereabouts to closer to 10:1.
Thanks. |
stownsen914 |
Jan 28 2022, 07:58 PM
Ressurecting this thread as I'm unable to run the spreadsheet (for some reason my mac doesn't like the .xls file) to calculate shims / compression ratio change. In short I want to reduce the compression of an engine from 12:1 or thereabouts to closer to 10:1. Thanks. I'll be curious what folks say about type 4 motors, but I know for 911s you don't want to have a deck height more than .060". Better to reduce compression in the dome rather than at the perimeter of the piston. Shimming to reduce compression does the latter, of course. |
Lo-Fi Version | Time is now: 15th May 2024 - 08:23 PM |
