> 9140430200 914-6 Adriatic Blue restoration Vintage Excellence, this thread covers the restoration of 914-6 #200
VintageExcellence
post Mar 8 2018, 12:20 PM
I have been a Porsche enthusiast since the mid 90s. Had a few 914s and converted them to 6s and had fun. Then I wanted a real 914-6 so I could have the genuine article, a car to restore to my own standards. In the mid 2000s you could find a beater 914-6 driver for $15k and a nice "restored" car for $25k. The restored cars back then were only restored within the dollar amount of their value or a slight bit over, these restorations had something to be desired and I thought I could build a better car myself out of a very good solid project car. I ran a classic car dealership in 2006, I looked at hundreds of cars per month for the dealership, snuck in a 914-6 search each day for a year... Then I found this car:
1970 Porsche 914-6, 2.0L, chassis# 914.043.0200, engine# 6404086 (Blue, 72,000 mi, steel wheels, needs work) in Houston, TX. Ph xxxxxxxxxxx Asking $13,000
This car was driven until late 1977 and then stored in my garage and totally neglected since I have been busy with other problems. Unfortunately I have lost the documentation on this car, so I will try to describe its history, but cannot back up many of my statements with tangible evidence.
I bought it used from a Porsche dealer (Holbert in Warminster, PA) in 1972 or early 1973 while I was living in northeastern Maryland. In fall 1973 I moved to Houston, Texas. It was maintained in Houston by the Jimmy Adams shop, which specialized in Porsches and VW's, and I drove it nearly every day. At some point (probably around 1976) the shop owner convinced me that Porsche 6-cyl engines needed a lot of care and would need an overhaul, so probably at about 60K mi (just my guess) the engine was torn down, rings, bearings, etc replaced, but I have no documentation. Adams said the pistons were higher compression than stock. In spring 1977 I was offered a temporary job in Austria, and the car was shipped back to Europe. I got to drive at 90 mph to work on the autobahn for a few months. I have documentation that the clutch was rebuilt by Porsche Wien-Liesing at 68K mi. In the ship on the way back to the U.S. the driver's door was dented. In late 1977 I noticed a lot of rust under the battery and on that side on the exhaust system. Also, the brake master cylinder started to leak. I took various things apart and cleaned and primered the battery area, but at that point (1977-early 1978) I became very busy, my job situation became unstable, and I have not touched the car since except to roll it out, clean a little dirt and put Armor-All on the vinyl last month. It has been in a closed garage but in a very humid climate since the beginning of 1978. I am looking for someone who wants it as-is to refurbish. I have been warned by an engine expert not to try to turn it over because he suspects rust internally.
On the way back from Europe the shipping company sprayed a brown polymeric goo on the outside of the car (esp. chromed parts) which was very hard to remove. In pictures of the car some brown is rust but some is this polymer. Also, the primer I put around the battery area is tan (almost rust) color. A prospective buyer will really have to examine it in person to decide, but I believe that someone can restore the car without major work. The fuel tank has been stored dry on a high shelf in the garage since 1978. In 77-78 the left door liner was removed and stored in preparation for removing the door dent, but this was never attempted. The front hood was removed and stored, but during storage a small patch of severe rust formed on the leading edge of the hood. In 77-78, besides putting primer in the battery area, I removed the exhausts and riveted pieces of galvanized sheet metal over rust holes in the heater boxes. More pictures on request.
Good old Dale said that he figured himself a hot shot when he got his PHD in the early 70s. He celebrated by walking in to Holbert's to buy a Porsche. Without the biggest budget he could not quite get into a 911. Maybe a 912 would work... the salesman took him over to a discounted 914-6 trade in with very low miles. Dale got the car for a great price and the moved to Texas and used the car as his primary driver. He got a job in Austria to work on the design of a power plant behind the iron curtain of the USSR and the 914-6 was shipped there to use as his driver. The power plant was canceled and Dale came back with the car. In 1977 he saw that battery acid had eaten the battery tray, this acid also dripped on the passenger heat exchanger which cause a few small holes. Dale panicked and took the battery out, the heat exchangers off and removed the front hood to get the fuel tank out (afraid of hidden rust down there too). This is the lesson to learn, he removed 3 critical functioning items from the car and ran out of time. The car then sat in his garage from 1977 till 2006 and was really a time capsule of originality.
The car sat on Pelican classifieds for a while and I made an offer, Dale accepted $9k for it and I flew out to see the car in person. Dale met me at the airport with a sign that simply read "914-6". He was a geeky scientist looking guy and not someone you would guess was a Porsche owner. I interviewed him about the car in the car ride and he was fascinated why I would want to know all this about his old car. The car sat in his single car enclosed garage, it was like a barn find pulling it out, unfortunately the front hood was rusted because he put it in a corner low spot that flooded every once and while. The heat exchanger had some slight rust but they were an easy repair. The rest of the car was complete, untouched, and 100% original. The full tool kit was there, owners manual, and some of the records. The battery tray was rusted through but none of the rust passed into the frame area and the rest of the body was rust free. I pulled out $9k in cash, Dale and his wife almost fell over, he was shaking as he counted the money inside his house. This was obviously a big sale for him and I assured him the car was in good hands and off I went. $700 to ship to my place in California.
Then I went down a rabbit hole and thought I would triple my efforts into used Porsche sales and opened a restoration shop using a name I had created in 2000.... Vintage Excellence
I had purchased a project 911S and this 914-6 as projects that I could tuck away and restore once production was up and running in the restoration shop. My dream of owning a perfect 914-6 and early 911S was on its way. I started the grab for NOS parts for my cars. These cars had to be perfect, I would use my knowledge from trolling VW & Porsche swap meets starting in 1994, expertise from a Porsche parts sales business started in 1997 thousands of parts sold and dozens of parted out 914/912/911s later, I worked for a shop called Oest Enterprises in Torrance for Dieter R. Oest restoring old Porsches and dealing with Dieters massive used parts inventory - Dieter was a former Vasek Polack 935 crew chief and a long time racer. I had worked for a kooky character named Bill Higgins who advertised out of the paper Auto Trader for many years selling classic Porsche parts - there I parted out cars and watched Bill flip a bunch of wrecks, I could not stand the junk car sales so I went out on my own at that point. I put myself through college via the Porsche parts and car sales business and learned plenty by the time I got my degree. I bought a suit and was interviewing for all these silly corporate jobs and I didn't like it so I took a few months off. Then through a friend I got the job at the dealership Cardiff Classics as the General Manager which brings us back to the beginning of the story.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
4 Pages V < 1 2 3 4 >
Replies(40 - 59)
johnhora
post Sep 18 2018, 02:13 PM
Post #41
Following this nice build.. (IMG:style_emoticons/default/popcorn[1].gif)
VintageExcellence
post Sep 18 2018, 03:22 PM
Post #42
I remember 914s on the road everywhere when I was a kid. When I graduated high school in 94 I saw the best you could find 73 914 2.0 in signal orange for $5,000 and thought someday I will get one. All the parts were still available but no one would pay $600 for an NOS dash or a pair of chrome bumpers. Flash forward 20 something years and I have this car that I stashed away many years ago and I am finally building it.
My professional work is sales and restorations of 911s. It is fun to switch gears and put together a 914-6 with all the best parts and to the same level as the 911S cars I build. This is my once in a lifetime 914 build. By the way I have had over 10 years to gather parts. The parts that count are original and these days it seems you can’t find near as much as you used to. Unfortunately the nature of the parts - they are flimsy and get damaged in the sun, I used to see these cars stored on the side of houses in Southern California all the time - all the interior parts and rubber rotted out.
VintageExcellence
post Sep 18 2018, 03:29 PM
Post #43
I also remember going to Ecology Auto Wrecking in the late 90s to pull good parts for cheap prices. They always had 4-8 914s in there. So many 914s were thrown away because the reliability. You saw complete 2.0 cars dumped in the junkyard with cobwebs on it, nothing else wrong, but once in the yard they were trashed.
VintageExcellence
post Sep 18 2018, 04:31 PM
Post #44
This trunk although much simpler than a 911 was still difficult to get right. The flaps in the defrost flappers were broken, took a while to find some replacement parts but it’s all original and working now. The fuel tank goes in next.
VintageExcellence
post Sep 18 2018, 06:40 PM
Post #45
Time for fuel, wait engine goes in first.
rstover
post Sep 18 2018, 06:59 PM
Post #46
QUOTE(VintageExcellence @ Sep 18 2018, 05:31 PM) *
Beautiful. Just exceptional.. Would you mind sharing what you used for pads for the gas tank?
VintageExcellence
post Sep 18 2018, 08:04 PM
Post #47
QUOTE(rstover @ Sep 18 2018, 05:59 PM) *
Thanks for the kind words. I was wondering what the heck was used to pad the tank. I think I spotted it on another 914 - perlon carpet. I took an old 911 trunk carpet and cut some squares. Looks great, fits great, seems like something Porsche would do.
I always overdo my trunks, it’s a major utility area for the car so taking your time here will make the car work so much better. Unfortunately most of it gets covered up.
Engine/trans will be done tomorrow and probably go into the car, let’s hope there are no holdups.
VintageExcellence
post Sep 18 2018, 09:56 PM
Post #48
QUOTE(Martin Baker @ Sep 16 2018, 01:11 PM) *
What paint (brand/type) did you use on the car? Glasuirt? Single stage? Looks great!
MB
Glasurit 22 line single stage. Always single stage.
pete000
post Sep 18 2018, 10:48 PM
Post #49
This is going to be one Top Gun six !
AHudson
post Sep 19 2018, 09:24 AM
Post #50
Agreed on the trunk space. It's an area most people look and say, 'Yeah, so what, a trunk.' But when it's as nice as yours is going to be (already is!) it'll stand out that much more.
Have you resolved what to do about the tar goo that goes atop the shock towers or are you going to leave it nice and shiny?
Either way, love the build and especially the color. Subscribed!
Cairo94507
post Sep 19 2018, 09:43 AM
Post #51
Michael
AHudson raises a great point. What are you going to do with the shock towers? I have decided to leave mine clean which I am sure will cause some consternation amongst the ranks. (IMG:style_emoticons/default/beerchug.gif)
defianty
post Sep 19 2018, 10:32 AM
Post #52
Looks fantastic. I just a few months away from doing all this myself and quite excited about it too.
VintageExcellence
post Sep 19 2018, 07:53 PM
Post #53
Not sure on the goo on top of the shocks. It wouldn’t go on until after the car is well dialed in. It’s gross so might not do it. They just lathered it on with a brush so it is a bit chaotic and you need hot tar to do it right.
Engine is together after much fussing of little parts.
VintageExcellence
post Sep 19 2018, 08:18 PM
Post #54
Side view
Larmo63
post Sep 19 2018, 09:55 PM
Post #55
Wow that looks great, Mark!!!
I'll bet the 914-6 rear emblem I bought from you is off of this car?
VintageExcellence
post Sep 19 2018, 10:14 PM
Post #56
QUOTE(Larmo63 @ Sep 19 2018, 08:55 PM) *
Yes that was the original emblem from this car. The NOS one replaced it.
Krieger
post Sep 19 2018, 10:44 PM
Post #57
Nice build! Your work is excellent!
VintageExcellence
post Sep 20 2018, 08:24 AM
Post #58
Glad I put away a nice roll bar pad a number of years ago
post Sep 20 2018, 09:11 AM
Post #59
914-6 GT in waiting
AB. The color of my first 914 when I was 16. Love it!
Ferg
post Sep 20 2018, 10:29 AM
Post #60
Great work. (IMG:style_emoticons/default/smilie_pokal.gif)
- Lo-Fi Version Time is now: 22nd November 2026 - 06:12 PM
