So I happen to have a '67 911 front suspension... |
Tdskip |
Mar 10 2018, 08:27 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I swapped out my '67 912 original front suspension for an SC, which means I have the '67 full set up sitting in the garage.
Any reason not to use it on the '74 914/6 project? |
Mar 10 2018, 08:52 AM
I think you can but might not be the best option. Might want to see what it’s worth to an early 911 guy / earlySregistry
Larmo63 |
Mar 10 2018, 10:48 AM
Use later SC struts if you can find them, you'll have a better choice on brake options. |
IronHillRestorations |
Mar 10 2018, 10:49 AM
The early set up uses pinch bolts to hold the struts to the lower ball joint. This was replaced with the wedge bolt system in '71 (IIRC).
I'd sell to an early 911 guy. |
dr914@autoatlanta.com |
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
not in a million years, 911 front end was totally changed in 69 never to look back on that antiquated stuff. Sell it to a short wheelbase guy
I swapped out my '67 912 original front suspension for an SC, which means I have the '67 full set up sitting in the garage. Any reason not to use it on the '74 914/6 project? |
Tdskip |
Mar 10 2018, 10:50 AM
Thank you for the confirmation gentlemen, that's why I took it off the car in the first place.
Lo-Fi Version | Time is now: 15th May 2024 - 11:10 AM |
