Sons 1st porsche. |
Sons 1st porsche. |
mb911 |
Mar 10 2018, 03:41 PM
914 Guru Group: Members Posts: 6,820 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
mb911 |
Mar 11 2018, 02:38 PM
Minor update is replaced fuel line from tank to fuel pump.. Not ideal I am sure the factory piece is formed but we were trying to get it to fire up.. Good news is the engine turns over, has spark, and compression.. Now need to buy a battery as was just using jumper cables.. Then check all connections and try to get fuel pump to turn on..
porschetub |
Mar 20 2018, 12:36 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Minor update is replaced fuel line from tank to fuel pump.. Not ideal I am sure the factory piece is formed but we were trying to get it to fire up.. Good news is the engine turns over, has spark, and compression.. Now need to buy a battery as was just using jumper cables.. Then check all connections and try to get fuel pump to turn on.. Yes the tank to pump hose has a larger formed end on the tank,a bit hard to fit much else but you could,in regards to the sensors you can use BMW ones and they are a little cheaper but the wires are a different length but still work,if possible give the holes in the sensor block a bit more clearance because they are too tight to start with...you will thank yourself later. I have used the aftermarket FAE ones from Pelican but not used them long enough to tell the quality. Fuel pumps have a habit of sticking up if the car has been sitting a while,ensure you have 12v getting to it,the connections tend to corrode on the pump due to its location. A failed pump isn't such a big deal as it is common to other vehicles and not super spendy. Good luck and enjoy the father/son project. |
mb911 |
Mar 20 2018, 04:10 PM
Minor update is replaced fuel line from tank to fuel pump.. Not ideal I am sure the factory piece is formed but we were trying to get it to fire up.. Good news is the engine turns over, has spark, and compression.. Now need to buy a battery as was just using jumper cables.. Then check all connections and try to get fuel pump to turn on.. Yes the tank to pump hose has a larger formed end on the tank,a bit hard to fit much else but you could,in regards to the sensors you can use BMW ones and they are a little cheaper but the wires are a different length but still work,if possible give the holes in the sensor block a bit more clearance because they are too tight to start with...you will thank yourself later. I have used the aftermarket FAE ones from Pelican but not used them long enough to tell the quality. Fuel pumps have a habit of sticking up if the car has been sitting a while,ensure you have 12v getting to it,the connections tend to corrode on the pump due to its location. A failed pump isn't such a big deal as it is common to other vehicles and not super spendy. Good luck and enjoy the father/son project. Any idea of the bmw part numbers to make it cheaper. Looks like one is only 30 dollars(porsche number) the other is about 100.. |
porschetub |
Mar 21 2018, 01:23 PM
Minor update is replaced fuel line from tank to fuel pump.. Not ideal I am sure the factory piece is formed but we were trying to get it to fire up.. Good news is the engine turns over, has spark, and compression.. Now need to buy a battery as was just using jumper cables.. Then check all connections and try to get fuel pump to turn on.. Yes the tank to pump hose has a larger formed end on the tank,a bit hard to fit much else but you could,in regards to the sensors you can use BMW ones and they are a little cheaper but the wires are a different length but still work,if possible give the holes in the sensor block a bit more clearance because they are too tight to start with...you will thank yourself later. I have used the aftermarket FAE ones from Pelican but not used them long enough to tell the quality. Fuel pumps have a habit of sticking up if the car has been sitting a while,ensure you have 12v getting to it,the connections tend to corrode on the pump due to its location. A failed pump isn't such a big deal as it is common to other vehicles and not super spendy. Good luck and enjoy the father/son project. Any idea of the bmw part numbers to make it cheaper. Looks like one is only 30 dollars(porsche number) the other is about 100.. Ben sensors...any one of the 1986 or latter 3,5 and 7 series with Motronic EFI (same system as 944) will work if memory serves me. As you have the later car with the plastic tank I would doubt you could bond a fitting back in there,a replacement tank would be a better option and shouldn't be expensive to buy used,I seem to remember they can be a bugger to change however never done that myself so don't really know. |
Lo-Fi Version | Time is now: 4th May 2024 - 01:23 AM |
