Can we have a chat about rear sway bars please? |
Tdskip |
Mar 11 2018, 10:03 AM
Advanced Member Group: Members Posts: 3,681 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
So I scored a 19mm front bar, wondering now about rear bars. This is for a fast road, touring event, ‘74 with a 3.2 build.
I like cars that are tidy in their handling but would prefer not to leave the road backwards... Also looking to confirm that I can always address the real sway bar later because it’s bolt on that does not require any welding work? Take me to school here please! |
Dave_Darling |
Mar 12 2018, 03:15 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
It also depends on what else you've done to the suspension. Remember, the suspension is a system, and is usually best approached as a system.
For instance, stiffer rear springs can give you rear roll rate instead of a rear sway bar. Likewise, larger front torsion bars can give you front roll rate instead of a larger front sway bar. Tire sizes, alignment, and even driving style also play into things. --DD |
infraredcalvin |
Mar 12 2018, 09:15 PM
Distracted Member Group: Members Posts: 1,504 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
It also depends on what else you've done to the suspension. Remember, the suspension is a system, and is usually best approached as a system. For instance, stiffer rear springs can give you rear roll rate instead of a rear sway bar. Likewise, larger front torsion bars can give you front roll rate instead of a larger front sway bar. Tire sizes, alignment, and even driving style also play into things. --DD (IMG:style_emoticons/default/agree.gif) Best advice thus far... |
Lo-Fi Version | Time is now: 23rd April 2024 - 12:03 AM |
