Can we have a chat about rear sway bars please? |
dr914@autoatlanta.com |
Mar 12 2018, 09:04 AM
914 Guru Group: Members Posts: 7,813 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would not use any rear sway bar with a 19mm front. The sixes are already tail happy and a rear bar would only accentuate that.
So I scored a 19mm front bar, wondering now about rear bars. This is for a fast road, touring event, ‘74 with a 3.2 build. I like cars that are tidy in their handling but would prefer not to leave the road backwards... Also looking to confirm that I can always address the real sway bar later because it’s bolt on that does not require any welding work? Take me to school here please! |
Mar 12 2018, 03:15 PM
It also depends on what else you've done to the suspension. Remember, the suspension is a system, and is usually best approached as a system.
For instance, stiffer rear springs can give you rear roll rate instead of a rear sway bar. Likewise, larger front torsion bars can give you front roll rate instead of a larger front sway bar. Tire sizes, alignment, and even driving style also play into things. --DD |
Tdskip |
Mar 12 2018, 03:25 PM
Advanced Member Group: Members Posts: 3,681 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Thanks for the discussion and thoughts.
Looks like the safest bet right now is to install the brackets so they're there if I ever want to install a bar but leave a rear bar off for now and just drive her and see how she feels , yes? |
colingreene |
Mar 12 2018, 03:33 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
i have a 20mm front bar 19mm torsion bars up front
140 pound rear springs and a stock sway bar. the rear sway bar makes the car more predictable for me on the street and easier to power over steer. |
jmitro |
Mar 12 2018, 04:54 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
It also depends on what else you've done to the suspension. Remember, the suspension is a system, and is usually best approached as a system. For instance, stiffer rear springs can give you rear roll rate instead of a rear sway bar. Likewise, larger front torsion bars can give you front roll rate instead of a larger front sway bar. Tire sizes, alignment, and even driving style also play into things. --DD +1. |
gothspeed |
Mar 12 2018, 05:57 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Can we have a chat about rear sway bars please? I like them, a lot of people don't. I run a stock rear bar on my car. (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/agree.gif) You can look at my car next time you see it. I have factory mounts as my car is an early '73 appearance group 914S model. (IMG:style_emoticons/default/beer.gif) I welded the pickups on the consoles and firewall for adjustable struts too. I like having the rear sway bar, what's not to like? (IMG:style_emoticons/default/agree.gif) |
infraredcalvin |
Mar 12 2018, 09:15 PM
Distracted Member Group: Members Posts: 1,504 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
It also depends on what else you've done to the suspension. Remember, the suspension is a system, and is usually best approached as a system. For instance, stiffer rear springs can give you rear roll rate instead of a rear sway bar. Likewise, larger front torsion bars can give you front roll rate instead of a larger front sway bar. Tire sizes, alignment, and even driving style also play into things. --DD (IMG:style_emoticons/default/agree.gif) Best advice thus far... |
rhodyguy |
Mar 13 2018, 10:51 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
OEM F&R bars, stock torsion bars, Koni red ext adj F&R, 100# springs on adj perches. Elephant poly-bronze upfront. Dreamy on the road. Predictable.
mbseto |
Mar 13 2018, 12:25 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Can you tell if you're lifting a wheel while driving, or do you need someone outside the car watching?
stugray |
Mar 13 2018, 03:05 PM
I run no rear bar on my racecar but I have 225# springs in the rear
jmitro |
Mar 13 2018, 05:22 PM
Lo-Fi Version | Time is now: 23rd April 2024 - 07:35 AM |
