FOUND what I needed, Cheep AX spring FOUND a NEW SET |
rfinegan |
Mar 12 2018, 11:16 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I need a set of cheep 2.5 coil over springs 10" 140lb to baseline my replacement Koni Rear Shocks /springs. I know the 200lbs that are on there are going to be way to stiff for my needs...Let me know what you may have
-Robert looking for 125-150 range to work with stock rear sway bar and stock front springs and 19 Front way bar. 205/60/515 Yokohama on Enkie wheels (narrow body 75) |
rfinegan |
Mar 13 2018, 05:52 PM
I think I can get some 2.5x10 125 lb springs from Summit or Jegs ( store brand) for 37 bucks each..May be good for me on the street???
I need a set of cheep 2.5 coil over springs 10" 140lb to baseline my replacement Koni Rear Shocks /springs. I know the 200lbs that are on there are going to be way to stiff for my needs...Let me know what you may have -Robert looking for 125-150 range to work with stock rear sway bar and stock front springs and 19 Front way bar. 205/60/515 Yokohama on Enkie wheels (narrow body 75) |
rfinegan |
Mar 23 2018, 05:20 PM
Got a cheep set from Summit racing...Thanks
Lo-Fi Version | Time is now: 25th April 2024 - 02:23 PM |
