Houndstooth seats - On sale to end of the month, Same price as vinyl (actually $20 a seat less now) |
Mikey914 |
Mar 17 2018, 08:19 AM
The rubber man Group: Members Posts: 12,622 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you want to buy a set I can make them. Want me to put up a listing for you. I can't see stocking them, but if you order I'll make. Not my personal favorite, but wouldn't go well in any of my cars either.
Nutter965 |
Mar 20 2018, 03:54 AM
Member Group: Members Posts: 139 Joined: 17-August 14 From: Uk Northern Ireland Member No.: 17,784 Region Association: None |
Mark, quick question, can you do black and white centres to suit a pre 71 seat set up ?
Mikey914 |
Mar 21 2018, 10:23 PM
Yes and no.
The drivers yes. the passenger side no. But you mush have a camera in my shop as we just did the drivers and passengers in black and white hounds tooth. they are are a little more expensive in that you will need the "3 piece" back pad, that in your configuration is only 2, and we will need to credit the back bolster that would normally come with the seat. I can post some pics tomorrow. |
Mikey914 |
Mar 23 2018, 12:41 PM
The fixed back and bolsters are done. the "back pad" section we are sewing more up.
Attached thumbnail(s) |
bahnzai |
Mar 25 2018, 01:10 PM
Member Group: Members Posts: 304 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
Mark,
What else is needed to complete a standard seat (‘72-‘76) with this houndstooth cover? I assume the bolster and back pieces? Foam as needed? Thanks!! |
Mikey914 |
Mar 25 2018, 09:41 PM
All the kits assume that you have the sub components below the vinyl. The fixed base, and foam, as well as the backpad foam and fiberboard.
We do sell a foam replacement for the base. If you need a foam section I think we could cut one up, but I’ll have to figure out what we need to charge. Mark |
Lo-Fi Version | Time is now: 28th March 2024 - 07:02 AM |
