Wipers park position |
partwerks |
Mar 13 2018, 06:31 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I was thinking there was some kind of adjustment if a person wants the wipers to park on the left, or right hand side, but don't recall?
Rand |
Mar 13 2018, 06:41 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Isn't it just a matter of swapping and reclocking the blades?
mepstein |
Mar 13 2018, 06:42 PM
914-6 GT in waiting Group: Members Posts: 19,238 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Parking on the left is much better unless you live in an area that doesn’t rain.
windforfun |
Mar 13 2018, 07:00 PM
Senior Member Group: Members Posts: 1,775 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
And the damn wiper on the driver's side, if parked on this side, will overlap the windshield trim.
mepstein |
Mar 13 2018, 07:06 PM
And the damn wiper on the driver's side, if parked on this side, will overlap the windshield trim. Not if it’s adjusted right Attached image(s) |
windforfun |
Mar 13 2018, 07:09 PM
Cool. Obvious. Good to know. I 've seen so many not adjusted correctly.
fixer34 |
Mar 13 2018, 07:13 PM
Senior Member Group: Members Posts: 1,073 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
You mean like this? Green one in the center of the photo.
Remove the wiper motor/assembly, loosen the arm on the motor and rotate it 180 degrees. Reinstall but do not attach wiper arms. Park the wipers, install wiper arms pointing toward the passenger side. Cycle the wipers to make sure they move like you want, then tighten the arms. It may be possible to get to the motor arm with everything in the car... |
windforfun |
Mar 13 2018, 07:15 PM
I see mucho driver's side windshield trim overlap. Is this the factory setting?
branston |
Mar 13 2018, 08:38 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
gms |
Mar 13 2018, 09:04 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
SKL1 |
Mar 13 2018, 09:11 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
When I reassembled my "71 after a respray in 1988 I must have screwed up the wiring because they parked on pass side by accident. I adjusted them to park like the car above this post and liked them that way so I kept them. When I reassembled my '73 after the restoration I actually put the wires back on correctly so they park like the original. Kept them like that so I now have one of each...
( I luckily essentially never use the wipers anyway so it doesn't matter.) |
Firstcar |
Mar 13 2018, 09:17 PM
Obsessive amateur mechanic Group: Members Posts: 97 Joined: 17-March 11 From: MA -South Shore Member No.: 12,831 Region Association: North East States |
SKL1 |
Mar 13 2018, 09:18 PM
Elliot Cannon |
Mar 13 2018, 10:34 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Parked on the right side. Or as some would say, "the correct side". (IMG:style_emoticons/default/av-943.gif)
Attached image(s) |
Larmo63 |
Mar 14 2018, 12:10 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Porsche engineers designed them to park on the left (driver's) side so the first sweep cleans the water AWAY from the driver's vision.
You can buy right hand park wiper arms, btw. They are bent the proper way to the right. |
Wyvern |
Mar 14 2018, 12:28 AM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
I have flipped them on 911s and 914s ... to do it correctly I modify the arm to put the kink in it going the needed direction . I have done this by heating and bending and also cutting and welding. If you don't do this it looks odd.
trick-e |
Mar 14 2018, 04:57 AM
Still Learning Group: Members Posts: 111 Joined: 7-July 12 From: Traverse City, MI USA Member No.: 14,644 Region Association: Upper MidWest |
Convert to a right hand drive. That’s also an option.
Coondog |
Mar 14 2018, 05:59 AM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
A&P Mech |
Mar 14 2018, 06:36 AM
Member Group: Members Posts: 400 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
My wipers don't automatically go to a park position when they are cancelled. They just stop wherever they happen to be in the cycle when the switch is turned off. After reading through this thread, I am assuming they should? Any idea what could cause this?
mepstein |
Mar 14 2018, 07:56 AM
Porsche engineers designed them to park on the left (driver's) side so the first sweep cleans the water AWAY from the driver's vision. You can buy right hand park wiper arms, btw. They are bent the proper way to the right. (IMG:style_emoticons/default/agree.gif) parked on the right moves all the water directly in front of the driver and leaves it there. If you are moving, it flows up the windshield. So the driver’s side is always wet. Parking on the left directs the water coming off the hood away from the drivers field of vision. |
Lo-Fi Version | Time is now: 25th April 2024 - 05:17 AM |
