Rear Trailing Arm Bushings question |
Bates |
Mar 15 2018, 08:58 AM
Bates Group: Members Posts: 68 Joined: 27-December 13 From: Madison, Virginia Member No.: 16,800 Region Association: MidAtlantic Region |
I'm replacing the rear bushings and want to allow lubrication via grease fitting.
Do the inner diameter of the bushings pivot on the shaft or do the trailing arms pivot on the outer diameter of the bushings? Bushings seem tighter on the shaft, and that surface area is much smaller than the o.d. |
Mikey914 |
Mar 15 2018, 09:30 AM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The factory process I doubt was vulcanized. It would give you a part that was pretty much serviceable. That being said, the original process was very much like the A arm bushing install. Heat was definitely involved, just not fully vulcanized,
Lo-Fi Version | Time is now: 17th May 2024 - 09:17 AM |
