Call out to sbc converted teener owners, Harmonic balancer and timing marks |
HalfMoon |
Mar 15 2018, 09:25 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Owning a Renegade converted sbc 914, I've often wondered how other owners have solved the problem of not being able to see the timing marks on the harmonic balancer.
What was/is your solution (other than timing by ear)? Thanks! |
Mueller |
Mar 15 2018, 09:59 AM
Owning a Renegade converted sbc 914, I've often wondered how other owners have solved the problem of not being able to see the timing marks on the harmonic balancer. What was/is your solution (other than timing by ear)? Thanks! Cutting hole in firewall? Now with cheap remote cameras that you can plug into your phone or laptop that might work? |
HalfMoon |
Mar 15 2018, 10:25 AM
Owning a Renegade converted sbc 914, I've often wondered how other owners have solved the problem of not being able to see the timing marks on the harmonic balancer. What was/is your solution (other than timing by ear)? Thanks! Cutting hole in firewall? Now with cheap remote cameras that you can plug into your phone or laptop that might work? The remote cam might work.... I did cut an access panel in my wall (to access the water inlets), but sadly, the lip of the wall just above the harmonic balancer prevents being able to see the balancer and or the pointer. Not even sure if a cam could see it. Cutting the lip would be a no no as this is structural, right? |
Lo-Fi Version | Time is now: 18th May 2024 - 11:55 PM |
