Call out to sbc converted teener owners, Harmonic balancer and timing marks |
HalfMoon |
Mar 15 2018, 09:25 AM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Owning a Renegade converted sbc 914, I've often wondered how other owners have solved the problem of not being able to see the timing marks on the harmonic balancer.
What was/is your solution (other than timing by ear)? Thanks! |
914GT |
Mar 15 2018, 12:34 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I relocated the timing scale to the side of the balancer and made a new mark on the balancer corresponding to 0 deg at TDC. I can then easily check with the timing light looking from underneath the car on the driver side.
HalfMoon |
Mar 15 2018, 12:41 PM
I relocated the timing scale to the side of the balancer and made a new mark on the balancer corresponding to 0 deg at TDC. I can then easily check with the timing light looking from underneath the car on the driver side. That one's a good idea too, but kinda problematic (as would be my idea of the access panel in the cockpit) cause access to the dizzy is kinda difficult and thus would require two people. |
914GT |
Mar 15 2018, 02:08 PM
I relocated the timing scale to the side of the balancer and made a new mark on the balancer corresponding to 0 deg at TDC. I can then easily check with the timing light looking from underneath the car on the driver side. That one's a good idea too, but kinda problematic (as would be my idea of the access panel in the cockpit) cause access to the dizzy is kinda difficult and thus would require two people. I've never had a problem adjusting timing by myself. I check where it's at with the light then advance or retard as needed. A couple of iterations and it's dialed in. If there was a reason to check timing often then I could see the access hole in the trunk would make it easier. |
Lo-Fi Version | Time is now: 20th May 2024 - 12:16 AM |
