FS Peddeling Pedals - Cross Post from Pelican, Price for 914 World member $50 off. |
bdstone914 |
Mar 15 2018, 11:31 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
This is a cross post from Pelican where I posted pedal sets for 914 911, 912 1965-1976. https://forums.pelicanparts.com/porsche-911...965-1976-a.html 1 Short Wheel Base 1965 -1968, 911 & 912. This set uses a longer brake rod and does not use a brake light switch mounted on the housing. The housing I used build this set has the bracket for the switch allowing upgrade to the dual circuit master cylinder. Most of the original housing are in very poor shape. 2. LBW 1969-1973 911, 912, and 914 1970-1976 This set uses the shorter brake rod and a switch on the housing. The only difference between the 911 and 914 is the upper clutch pedal. The correct pedal is included. Does not fit 914-6. I can build one but need the special accelerator crank with the tab for the throttle from our set first. 3. 911 1975-1976 with power brakes. This set uses a long brae rod that goes up to the 4. 911 1974-75 without power brakes. This set has a blue clutch spring on the side. Still uses the brake rod on the brake pedal. I prefer to sell the sets on a core exchange basis for $350. If you do not have a core the charge is $100 for the #1 and #2, and $150 for #3 & #4. I take checks and Paypal. You can email me a picture of your pedals at bdstone914@aol.com PM me for my phone number if you ant to talk. I accept incomplete cores at adjusted core value. More pictures and details available upon request. Attached thumbnail(s) |
worn |
Mar 17 2018, 02:42 PM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Those are works of art. Beautiful |
Lo-Fi Version | Time is now: 2nd May 2024 - 08:13 PM |
