Dashtop crack can it be repaired?, Can it be done? |
jrblackbox |
Mar 15 2018, 12:15 PM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
Anybody have any luck repairing small cracks in the dashtop? maybe some type of filler or vinyl repair? TIA
Mikey914 |
Mar 19 2018, 09:24 AM
The rubber man Group: Members Posts: 12,659 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
It's basically the way they were made.
The OEM version was a 2 sided mold. That the thin vinyl (surface) was pulled into one side and the the frame was put into the other side. Foam was them shot into the cavity. Thia gave the dash some "give". Unfortunately, differential rates of expansion and contraction work to create cracks at focal points for the stress. This is why they all crack in the same areas. We believe ours to be better in that using a more dense material that self skins the density is more uniform and the substructure is more stable. This is all done under very high pressure (as some of you may remember me mentioning blowing out my molds. It was definitely a trial and error process, and there are still variables we have to control, but we've finally got it down. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 01:03 AM |
