gas tank pipe sealing |
JFG |
Mar 15 2018, 01:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I lost the tear down pics so i have no images of how it came apart.
Can someone help me with the way to seal the outlet / return pipe that screw onto the bottom of the tank. I have aluminium washers and fibre washers. I've tried with both, the fibres leak badly. They were squashed between the tank and the round collar fixed to the small steel pipe tail. I've tried using just an aluminium washer in the same position as above but still a slight leak. As the retaining nuts are a soft alloy i can't tighten them anymore. Just in case i do ruin them trying to seal them, does anyone know the correct thread size of the outlets on the tank? |
sithot |
Mar 15 2018, 01:52 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
Auto Atlanta:
https://www.ebay.com/i/231867072992?chn=ps&fl=a I've used this too. https://henrichinc.com/shop/gasoila-soft-se...IhoC49UQAvD_BwE |
Rob-O |
Mar 15 2018, 01:53 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I believe both go on each outlet, not one or the other. So tank>fiber washer>aluminum washer>tank nipple.
Others can correct me if I’m wrong. Also, you may want to download the PET on your computer. Go to Porsche’s website. Classic area. It’s the parts list with exploded diagrams of the car. Extremely useful. |
gothspeed |
Mar 15 2018, 02:07 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Good info above. thanks for posting (IMG:style_emoticons/default/smile.gif)
JFG |
Mar 15 2018, 02:33 PM
The catalogue shows outlet has 1 aluminium washer
The return shows 1 fibre washer only so i'm not confident this is correct. I think as detailed above is correct even though one is m10 & one is m8. Ideally i would like to fit something like a copper pipe/union, maybe from something like a rally parts provider or similar but i need to know the thread size. |
mgphoto |
Mar 15 2018, 03:24 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
both washers should be copper, the AA versions are a bit small but they do work with the correct "crush".
Harbor Freight has a collection of copper washers, pretty cheap. You could heat them cherry red, let them cool and they will crush very nicely like the exhaust head gaskets. |
cary |
Mar 15 2018, 08:37 PM
Like mgphoto just said both are copper.
The filter sock does have an aluminum base. |
worn |
Mar 15 2018, 09:47 PM
can't remember Group: Members Posts: 3,143 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
both washers should be copper, the AA versions are a bit small but they do work with the correct "crush". Harbor Freight has a collection of copper washers, pretty cheap. You could heat them cherry red, let them cool and they will crush very nicely like the exhaust head gaskets. I do this as a public service every year. To anneal copper you heat to a dull red, or cherry red if you have the nerve, then quench in cold water. Not the same as steel. If you can afford solid gold or silver it is the same. Air cooling these metals can be used as a hardening technique. |
Mike Bellis |
Mar 16 2018, 06:32 PM
both washers should be copper, the AA versions are a bit small but they do work with the correct "crush". Harbor Freight has a collection of copper washers, pretty cheap. You could heat them cherry red, let them cool and they will crush very nicely like the exhaust head gaskets. I do this as a public service every year. To anneal copper you heat to a dull red, or cherry red if you have the nerve, then quench in cold water. Not the same as steel. If you can afford solid gold or silver it is the same. Air cooling these metals can be used as a hardening technique. I did this with harbor freight copper washers. Worked great. Now I'm running AN fittings. But I always anneal my copper... |
bdstone914 |
Mar 17 2018, 07:03 AM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have never seen a copper washer used originally on a 914 tank. They are fiber. Not to say that is the best material. The ones I have found are hard and not a good fit. I made my own fiber washers out of gasket material. I use washers on top and bottom of the flange on the nipple. On the feed line the filter sock aluminum washer is part of the filter.
What is important is to hone flat the sealing surface on the tank. Did an install on a tank that would not stop dripping until we removed it, honed the sealing surface with a a piece o f wet or dry 240 grit on a flat steel lock. Copper should work fine if annealed. It is harder than aluminum and may tk more pressure to seal. The aluminum nuts are fragile. I am hesitant to apply too much torque in fear of stripping the threads. That whole original set up is a bit of a CF ( cluster fornication ). I found you and internally tap the threaded nipples to 1/4 NPT and install threaded nipples allowing use of lines that can be disconnect easily without removing hose clamps. I plan to go with AN-6 fittings to eliminate and sealing washers. This does require an external filter as the internal sock will no longer fit. My thought is get the crud out of the tank and change the filter rather than trap it in the tank. Ideally I want a threaded connection from the gas tank line to the tunnel lines. This would allow removal of a line to drain the tank. Maybe a Swagelok fitting on a SS line will work. Have to install it after the line is installed as the fitting will not go through the rubber block. |
JFG |
Mar 17 2018, 08:48 AM
I used an aluminium washer above and below the collar on the 2 tail pipes. Put as much force as I dared to use and no more leaking pipes. Needless to say a quick spin around the block to test and all is good.
rhodyguy |
Mar 17 2018, 10:49 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,055 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Rotary914 sells the fiber washers. Found in the member vendor sub-forum.
porschetub |
Mar 17 2018, 01:13 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I used fibre washers and had no leaks straight off,if you can't get a seal with any type of washer add a little Hylomar universal blue that will complete the seal ....only product I have used that is truly fuel resistant,great stuff.
bdstone914 |
Mar 18 2018, 07:47 PM
I used fibre washers and had no leaks straight off,if you can't get a seal with any type of washer add a little Hylomar universal blue that will complete the seal ....only product I have used that is truly fuel resistant,great stuff. Thanks for the tip. Never Heard of it before. HYLOMAR Universal blue gasket sealer is the leading non-setting gasket and sealing compound in use worldwide. It is used by many of the world's major automotive manufacturers and by several Formula 1 teams. It is non-hardening and non-setting, vibration resistant, seals surface imperfections and withstands rapid variations in temperature. Allows metal-to-metal contact and is resistant to combustion products, water, engine coolant, petroleum, lubricating oils, kerosene and fluorocarbon refrigerants. Dresses gaskets, threads and seals gaps up to .25mm. https://www.google.com/search?q=Hylomar+&am...ent=firefox-b-1 |
bdstone914 |
Mar 18 2018, 07:51 PM
Rotary914 sells the fiber washers. Found in the member vendor sub-forum. I have used his washers and they are like original and ok at best. I want a better seal. I found some SS washers with silicone rubber bonded to one side. Cant find both the large and small hole with correct OD. nee 8 x 16 and 10 x 16. |
rhodyguy |
Mar 19 2018, 08:31 AM
Bruce, did Robert's washers leak?
bdstone914 |
Mar 19 2018, 08:45 AM
Bruce, did Robert's washers leak? The tank leaked with his washers more because the small narro sealing surface n the tank nipples was not flat and clean enough. We had to remove the tank after trying several sealing methods. Honed the surface flat and carefully installed new seals. Need full size 16 OD and 8mm & 10mm ID. I do not like having two sizes. No need to. Looking at a better more simple system. so far the internal pipe thread does away with all washers but eliminate the internal sock, |
porschetub |
Mar 19 2018, 02:49 PM
I used fibre washers and had no leaks straight off,if you can't get a seal with any type of washer add a little Hylomar universal blue that will complete the seal ....only product I have used that is truly fuel resistant,great stuff. Thanks for the tip. Never Heard of it before. HYLOMAR Universal blue gasket sealer is the leading non-setting gasket and sealing compound in use worldwide. It is used by many of the world's major automotive manufacturers and by several Formula 1 teams. It is non-hardening and non-setting, vibration resistant, seals surface imperfections and withstands rapid variations in temperature. Allows metal-to-metal contact and is resistant to combustion products, water, engine coolant, petroleum, lubricating oils, kerosene and fluorocarbon refrigerants. Dresses gaskets, threads and seals gaps up to .25mm. https://www.google.com/search?q=Hylomar+&am...ent=firefox-b-1 Thanks, hope this info is help with those who have difficult sealing jobs,I was a Loctite guy for decades,the Hylomar has proved a better product for many applications that the Loctite doesn't cover (IMG:style_emoticons/default/beer.gif) . |
76-914 |
Mar 20 2018, 09:20 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,484 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've used Rotary914's gaskets and screens on three different cars without a hitch. Kevin already touched on the key. True and mated surfaces. (IMG:style_emoticons/default/beerchug.gif)
PASHN8 |
Jul 21 2019, 03:40 AM
Newbie Group: Members Posts: 8 Joined: 6-March 19 From: Melbourne, Australia Member No.: 22,938 Region Association: Australia and New Zealand |
Does anyone know the size of the two union nuts? Before I pull the tank, could they be 22mm?
**Edit Yes, they are 22mm. |
Lo-Fi Version | Time is now: 19th April 2024 - 09:42 AM |
