gas tank pipe sealing |
JFG |
Mar 15 2018, 01:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I lost the tear down pics so i have no images of how it came apart.
Can someone help me with the way to seal the outlet / return pipe that screw onto the bottom of the tank. I have aluminium washers and fibre washers. I've tried with both, the fibres leak badly. They were squashed between the tank and the round collar fixed to the small steel pipe tail. I've tried using just an aluminium washer in the same position as above but still a slight leak. As the retaining nuts are a soft alloy i can't tighten them anymore. Just in case i do ruin them trying to seal them, does anyone know the correct thread size of the outlets on the tank? |
rhodyguy |
Mar 19 2018, 08:31 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Bruce, did Robert's washers leak?
bdstone914 |
Mar 19 2018, 08:45 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Bruce, did Robert's washers leak? The tank leaked with his washers more because the small narro sealing surface n the tank nipples was not flat and clean enough. We had to remove the tank after trying several sealing methods. Honed the surface flat and carefully installed new seals. Need full size 16 OD and 8mm & 10mm ID. I do not like having two sizes. No need to. Looking at a better more simple system. so far the internal pipe thread does away with all washers but eliminate the internal sock, |
Lo-Fi Version | Time is now: 17th May 2024 - 05:19 AM |
