gas tank pipe sealing |
JFG |
Mar 15 2018, 01:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I lost the tear down pics so i have no images of how it came apart.
Can someone help me with the way to seal the outlet / return pipe that screw onto the bottom of the tank. I have aluminium washers and fibre washers. I've tried with both, the fibres leak badly. They were squashed between the tank and the round collar fixed to the small steel pipe tail. I've tried using just an aluminium washer in the same position as above but still a slight leak. As the retaining nuts are a soft alloy i can't tighten them anymore. Just in case i do ruin them trying to seal them, does anyone know the correct thread size of the outlets on the tank? |
PASHN8 |
Jul 21 2019, 03:40 AM
Newbie Group: Members Posts: 8 Joined: 6-March 19 From: Melbourne, Australia Member No.: 22,938 Region Association: Australia and New Zealand |
Does anyone know the size of the two union nuts? Before I pull the tank, could they be 22mm?
**Edit Yes, they are 22mm. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:26 AM |
