removing c.v. axles easy way |
davepalmer |
Mar 15 2018, 04:44 PM
Newbie Group: Members Posts: 1 Joined: 15-March 18 From: indiana Member No.: 21,970 Region Association: None |
take out all c.v. joint bolts and plates remove inner joint by driving thin straight blade screwdriver into gasket between joint and falange , between bolt holes gently pry turn 180 degrees and repeat . It will take several rotations repeatedly prying. REMOVING OUTER JOINT On rear of trailing arm near shock mount measure in from dust shield about 1 inch, should be on weld file or grind weld flat center punch for drill, start with 1/8 inch work your way up to 1/2 inch. Now you should be able to see the gasket between c.v. joint and stub axle Pry off like the inner joint.
TheCabinetmaker |
Mar 15 2018, 07:05 PM
I drive my car everyday Group: Members Posts: 8,299 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
First, welcome to the world. Second, I would never, ever, use a screwdriver to separate cv's. Are you saying to drill a hole in the bottom of the trailing arm. Not doing that either.
iankarr |
Mar 15 2018, 08:33 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,469 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I appreciate that your first post was intended to help other members, but friends don't let friends drive drill bits into trailing arms! For the outer CVs it's much easier to just remove the cv/stub axle as a unit. Here's a video on how to do that... https://www.youtube.com/watch?v=7a5ACf2xK6Y&t=9s I do use a screwdriver (carefully, as described in the Pelican how-to) to pry apart the joint. Curt...how do you do it? |
Andyrew |
Mar 16 2018, 09:49 AM
Easy way?
Remove the big nut on the stub axle, remove the trani side cv joint bolts, pull out cv joint. If exhaust isnt in the way you can do it in 20 mins for both sides. |
malcolm2 |
Mar 16 2018, 09:56 AM
Advanced Member Group: Members Posts: 2,729 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
It has been a while, but IIRC, they were on the bench and all I did was rotate the inner section until a ball came out.
Something like that. Oh yeah, wear gloves to keep the grease off of you. There are quite a few YouTube videos for total removal and re-installation. CV videos in general and specific 914 videos. Again, IIRC the only tool needed was a bench vise. |
TheCabinetmaker |
Mar 16 2018, 10:31 AM
(IMG:style_emoticons/default/welcome.png) I appreciate that your first post was intended to help other members, but friends don't let friends drive drill bits into trailing arms! For the outer CVs it's much easier to just remove the cv/stub axle as a unit. Here's a video on how to do that... https://www.youtube.com/watch?v=7a5ACf2xK6Y&t=9s I do use a screwdriver (carefully, as described in the Pelican how-to) to pry apart the joint. Curt...how do you do it? Ball peen hammer. Tap the side of the cv with the round side of hammer head while rotating. Not trying to reshape it, just a little vibration to loosen the bond. |
Lo-Fi Version | Time is now: 28th March 2024 - 01:40 PM |
