removing c.v. axles easy way |
davepalmer |
Mar 15 2018, 04:44 PM
Newbie Group: Members Posts: 1 Joined: 15-March 18 From: indiana Member No.: 21,970 Region Association: None |
take out all c.v. joint bolts and plates remove inner joint by driving thin straight blade screwdriver into gasket between joint and falange , between bolt holes gently pry turn 180 degrees and repeat . It will take several rotations repeatedly prying. REMOVING OUTER JOINT On rear of trailing arm near shock mount measure in from dust shield about 1 inch, should be on weld file or grind weld flat center punch for drill, start with 1/8 inch work your way up to 1/2 inch. Now you should be able to see the gasket between c.v. joint and stub axle Pry off like the inner joint.
TheCabinetmaker |
Mar 15 2018, 07:05 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
First, welcome to the world. Second, I would never, ever, use a screwdriver to separate cv's. Are you saying to drill a hole in the bottom of the trailing arm. Not doing that either.
Lo-Fi Version | Time is now: 11th May 2024 - 01:09 PM |
